April 15, 2010, 22:57 |
"Conjugate" Heat Transfer in CFX
Mona
Rep Power: 16 |
Sorry if this question is too simple:
Does the "conjugate" means the heat transfer happens during the fluid flow? Can I use this "conjugate" do "pure" heat transfer problem with nothing about "Fluid Dynamic" things? Thanks Mona |
April 16, 2010, 06:52 |
Rep Power: 143 |
Conjugate heat transfer means that there is heat transfer in the fluid (ie the Navier Stokes eqns and energy equation is being solved) and it is interacting with a solid region where only the heat equation is being solved.
Yes, you can use CFX to solve for a pure heat transfer simulation. Just set the material type to solid. |
April 16, 2010, 11:54 |
Mona
Rep Power: 16 |
Hi Glenn,
Thank you very much for answering my question. Can I ask another question: How to mesh the 2D geometry (just a rectangular)? And how to import it to CFX-Pre? Please answer me and in a simple way! Thank you in advance. |
April 18, 2010, 07:36 |
Rep Power: 143 |
April 20, 2010, 11:46 |
beiginezhad
Rep Power: 16 |
salam .khoob hastid?shoma cfx baraie model kardane looleie amoodi ke az biroon tahte hararate va dakhlesh abe va 2 fazi mishe kar kardid?too in sabke 2 fazi?
Conjugate Heat Transfer in CFX | Maher Al-Dojayli | CFX | 5 | November 1, 2011 21:06 |
CFX wall heat transfer coefficient | mactech001 | CFX | 1 | January 5, 2010 21:33 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
Heat transfer tube | Takeshi | Siemens | 4 | July 15, 2003 10:44 |
Heat Transfer Coeff. at Heat Flux Boundary | Rushyen | CFX | 6 | January 18, 2001 05:09 |
