Find location @ Line where a variable has a certain value
Old   March 29, 2010, 06:18
Default Find location @ Line where a variable has a certain value
camoesas is on a distinguished road
Hello!
I want to calculate the boundary layer thickness on a plate. For this I have created several Lines vertical on the plate an now I want to know the altitude atop the plate where the velocity reaches 99% of Uinf for the first time.
Is there any function that can tell me the coordinates of a certain variable on a Line?
Thanks in advance
camoesas is offline   Reply With Quote
Old   March 29, 2010, 07:13
Dmitry Volkind
dvolkind is on a distinguished road
If Uinf is constant and Y is my plane normal and starts with zero at the wall, I would use CEL:
MyFunction1 = v - 0.99*Uinf
MyFunction2 = step (MyFunction1)
Then I would make a plot MyFunction2 = f(Y)
Axis segment where MyFunction2 = 0.5 is my boundary layer thickness +-tolerance
It's the first thing that comes to my narrow mind, still I think there must be a better way.
dvolkind is offline   Reply With Quote
Old   March 29, 2010, 08:20
Hey Dvolkind,
Thanks for your reply! I have tried your solution but its still not working.
I get the Warning: "No Data exists for variable "my variable..."
I am working on that keep you updated.
cheers
Old   March 29, 2010, 20:10
The problem with Dmitry's approach is it does not interpolate correctly between nodes. If you are going to do a lot of this I would export the nodal values along the line and do it either with a program or in excel/matlab/whatever. Then you will be able to batch a few of them together to do it more efficiently.
Old   April 6, 2010, 03:51
Hey Glenn,
Thats what I am about to do. Export all the data to matlab.
However I thought maybe there is a easy solution for this first step in Ansys.
Thanks
Camoesas
Old   April 6, 2010, 12:02
Bruno
brunoc is on a distinguished road
Can't you just create an isosurface of 0.99*Vinf and then export this surface? When calculating the isosurface Post will interpolate values fine.
(remeber to clip it to the are you're interested in)
brunoc is offline   Reply With Quote
Old   May 6, 2010, 01:52
Dmitry Volkind
It's probably too late, but I think extracting a polyline from a velocity contour plot is a good idea.
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
[Gmsh] GMSH and OpenFOAM derath OpenFOAM Meshing & Mesh Conversion 44 September 4, 2008 05:09
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger benru OpenFOAM Meshing & Mesh Conversion 3 June 29, 2008 21:24
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
