Rotating-Stationary mesh interface in CFX
Old   March 30, 2016, 10:38
Default Rotating-Stationary mesh interface in CFX
Jack
Jack001 is on a distinguished road
I create a mesh of a single passage for a compressor blade using Turbogrid, then ship the mesh to CFX for simulations. The mesh consists of a single domain called Rotor. It consists of an inlet block, main passage, and an outlet block. I am using the Turbo Mode Wizard to set up the boundary conditions. The simulation is run with a "Rotating" Component type to simulate the rotation of the rotor. I don't have a stator down stream of the rotor, however I want to analyse the flow in the non rotating, stationary frame of reference at the outlet of the rotor as this is the flow that would impact the stator. Is there anyway of easily changing the interface between the main passage and the outlet block of my mesh so that the outlet block is not rotating?
Jack001 is offline   Reply With Quote
Old   April 1, 2016, 05:54
Maxim
-Maxim- is on a distinguished road
I'm not completely sure if I understand your question right. But you can evaluate variables like velocity etc. in a rotating domain in 'Stn Frame' (stationary frame).
Additionally, you can add a monitor point and select 'Stationary' as 'Frame Type'. I haven't used that yet, but I just added a monitor point for my next calculation - just to see what happens
Also a picture of your situation always helps us to understand your problem quickly.
-Maxim- is offline   Reply With Quote
Old   April 1, 2016, 08:59
turbo is on a distinguished road
The rotor outlet block in Turbogrid is needed only for mesh generation technique that we do not want really for CFD. What I use is to set the hub in the block as a counter-rotating wall so that it will be stationary. Shroud in the block will be included in your shroud stationary wall definition. Try to minimize the outlet block distance in Turbogrid, but still we need some. Good question.
turbo is offline   Reply With Quote
cfx
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
How to do proper set up for interface, if stationary & rotating domain is there rgunjegaonkar@gmail.com ANSYS 1 April 14, 2016 06:46
horizontal axis wind turbine- Issue in interface b/w stationary and rotating domain. srijithbbk CFX 5 February 22, 2016 04:20
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
