parallel and multiphase
Old   September 8, 2010, 07:24
Default parallel and multiphase
Zaktatir is on a distinguished road
hello,
i have a problem,
my calculation on 4 cpu's differs two much from this on 8 cpu's with the same setup? what did go wrong? (multiphase flow)
Zaktatir is offline   Reply With Quote
Old   September 8, 2010, 16:52
Claudia is on a distinguished road
What differs exactly? Did you use the same setup? Did the simulation reach convergence?
Claudia is offline   Reply With Quote
Old   September 8, 2010, 17:17
Thanks for the reply.
I am using the same setup, setting a transient simulation with normal convergene criteria..
when i ran the simulation on 8 cpus the solver command told me that libmp_hp was ignored and it worked and reach the final time.
Even if am monitoring the sims with a couple of Points, there is difference ( in the Rms values too)..
I am using a cluster with different nodes, every node has an other amount of cpus ( 4 and 8)..
thanks beforehand
Old   September 16, 2010, 08:45
Is there any idea why differences exist
Old   September 21, 2010, 13:56
joey2007 is on a distinguished road
Did you checked the usual suspects? Mesh quality and interfaces? Did you used double precision?
joey2007 is offline   Reply With Quote
Old   September 21, 2010, 15:22
yes off course. No Improve
But i as turned Turbulence Numerics to High Resolution, all the Simulations are the same.
Ansys Support are trying to resolve the Problem too.
Parallel Processing ocean wave multiphase model robb CFX 1 July 26, 2010 14:37
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 20:15
Problems with MFIX code and Parallel Processing. Fernando Pio Main CFD Forum 4 August 29, 2006 14:33
cfx4 parallel sover Problem!! HELP Richard.A CFX 2 August 3, 2002 03:54
parallel PHOENICS George Bergantz Phoenics 9 November 16, 2000 15:57
