November 6, 2010, 06:46 |
Ansys CFX getting Started
Rep Power: 15 |
I've never used Ansys CFX before. Could someone explain me the basic steps that I need to follow to get started? Thank you. |
November 6, 2010, 07:10 |
Rep Power: 16 |
The best documentation is that which comes with ANSYS Workbench (assuming this is what you are working with) which is available in amongst the folders in which it is installed in: .\Ansys Inc\v121\commonfiles\help\en-us\CFX\help\pdf\ Start with xmod.pdf which should be very helpful to you. consider xref.pdf and xthry.pdf The other pdf files are likely to be of less use to you. |
November 6, 2010, 11:22 |
Rep Power: 15 |
What I`m trying to do is modelling the heat transfer inside a can contaminated with microorganism that produces heat do to the metabolism.
Is there a package inside Ansys with the Fourier's Second Law with heat generation? |
Solidification in Ansys CFX (12.0 ) | mauricio | CFX | 2 | August 11, 2015 09:06 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
ANSYS CFX Tutorial | Rashid | CFX | 25 | December 20, 2012 01:22 |
URANS in ANSYS CFX | brissyben | CFX | 3 | October 6, 2009 17:35 |
2D Simulations in ANSYS CFX | CFDLife | CFX | 10 | August 1, 2008 14:04 |
