How to enable out file when "monitor run in progress"?
Like Tree1Likes
  • 1 Post By Matjaž
Old   November 10, 2010, 07:21
Default How to enable out file when "monitor run in progress"?
Lance
Lance is on a distinguished road
When running "Monitor run in progress" in cfx5solve my out file is disabled and there is no way to enable it again. Previously I got an warning that the out file is big and loading it would consume extra memory, but now it is disabled by default. The size of the file is only about 4-5 MB.
Im running the simulations on a linux cluster, and on all my jobs the out file is disabled. The same applies to "Monitor finished run". Also, when running a FSI simulation the Ansys Field Solver and Ansys out file are also disabled.
Any ideas on how to enable them? Tried to load different .mst files (workspace layout) but no success.
Lance is offline   Reply With Quote
Old   November 10, 2010, 11:14
Bharath kumar
bharath is on a distinguished road
hi lance,
1.have you accidentally closed the out file?
2.try to close all windows and open it again by opening the run directory may help.
3.otherwise stop the run completely and start it again by using results file.
bharath is offline   Reply With Quote
Old   November 10, 2010, 11:38
Lance
1) nope, havent closed it, it just says "disabled" in the header of the window where the out file used to be
2) done that, no effect
3) done that, made several restarts on lost of jobs, still the out file is disabled.
Does anyone know if cfx uses a settings file to display the graphs? I found a file called CFXPreferences.ccl located in /home/"user"/.cfx/ but couldnt find anything useful in it. Also, there were two filed called CFD-Post.conf and CFX-Pre.conf in /home/"user"/.config/ANSYS/ but nothing useful there either.
Edit: I've also unchecked "Disable this Monitor" on the monitor properties. Restarted cfx5solve, but no result.
Old   November 11, 2010, 11:49
playmaster
playmaster is on a distinguished road
In the solver toolbar, follow this:
Monitors/Out files ===> put check
playmaster is offline   Reply With Quote
Old   November 11, 2010, 11:56
playmaster
I wonder how did you get this size of the .out file. The .out file is usually less than 1 mb. For example, I did a simulation with a sheavy mesh, which the .res file is about 400 mb, but the .out file is just 300 kb. The .out file is just a text file. Did it may take 10000000000000000000 iteration?!
Old   November 12, 2010, 08:04
Lance
Thanks, but I've tried that too. No success.
My out files are getting big quickly, I've had a simulation running for three days and it's ~200 000 lines right now. I am solving FSI, and there's quite a few stagger iterations per time step, and each stagger contains about 4-5 coefficient loops. Guess thats why the out file becomes so big.
Lance
Old   June 18, 2014, 06:18
Matjaž is on a distinguished road
Hello
I've had the same problem. It turns out there is an aditional setting - if you right click in the "Out File" monitor window, and choose "Monitor Properties". There is a checkbox saying "Disable this Monitor" - when I unchecked it and pressed "Apply" the monitor started working.
Matjaž
EDIT: It seems that I have missed this procedure in your post before - it worked for me - I use windows and a local computer with a local hard drive.
njdyck likes this.
Matjaž is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
