December 22, 2010, 03:50 |
Interface w. Pitch Change:
Hello everyone,
I´m having a small problem with the way CFX stretches or compresses the flowfield when an interface with pitch change is used. Here is my Problem: I´m currently working on the simulation of a turbine testrig. The rig consists of 4 bladerows of which the 3d one is the rotor. Now, due to the number of blades in each row (and of course time and memory requirements) i´m forced to use interfaces with a pitch change. When i´m trying to do a simulation with a Frozen Rotor Interface (regardless whether steady state or transient), CFX stretches the flowfield between the interfaces as discribed in the manual. I´ve added two small pictures of a geometry that i used to test different interface configurations, where you can see the stretching cfx performs. This of course gives a rather wrong flowfield after an interface with a high pitch change (stretching of the wakes etc). In my case the pitch change after the rotor is from 15° to 24°, where the domain with the 24° is the one i´m most interested in. What i have seen from a few things that i have tried is, that CFX is able to "add" information to an interface by periodically adding data to the interface (i tried periodic domains with a different "lean" at the interface). My question is now whether there is a possibillity to prohibit the stretching on the interface, but to force the solver to do the add the information on side 2 of the interface by periodically copying the information from side 1 I hope that somebody is able to give me any advice or ideas how to solve the issue. thank you |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Pitch Change & interface connections | Kumar | CFX | 2 | August 5, 2007 02:57 |
Stage Interface Without Frame Change | Vikram | CFX | 2 | October 21, 2005 04:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
