Additional Variable BC
Old   May 22, 2010, 11:33
Default Additional Variable BC
Eli
Eli is on a distinguished road
Hi There
How can I set such a Boundary condition on wall for an "Additional variable" C:
K \partial C/\partial x= H (C-C0)
K and H are constants.
It's like heat transfer coefficient for wall but the variable is C.
Thank you so much
Eli is offline   Reply With Quote
Old   May 22, 2010, 12:42
Jordi
Jordi is on a distinguished road
It looks like a diffusion, is that your system? You do not provide very much info on your problem, but if it's like a heat convection, where C is temperature, then you can fix both temperature (C) and transfer coeff. (H) at the same surface, can't you?
Jordi is offline   Reply With Quote
Old   May 23, 2010, 18:49
Can do this with a gradient boundary with a CEL expression. Should be easy.
Old   May 24, 2010, 15:19
Eli
Thank you so much Glenn
Your advices have always helped me and other students.
But would you please explain it more for me? or refer me to a tutorial or example?
I don't know how to interpret a gradient boundary.
Thanks again
Old   May 24, 2010, 15:26
Eli
Thanks Jordi for your attention,
C is a scaler variable and shows kind of concentration in the simulation, I just don't know how to define the Left hand of equation.
Old   May 24, 2010, 18:42
Recast the equation as dC/dx=H/K(C-C0) then you have the gradient of the scalar at the boundary is a simple function. Set the function to a CEL expression and it is done.
Set this for the additional variable boundary condition at the walls.
Old   January 13, 2011, 08:57
Lance
Lance is on a distinguished road
Originally Posted by Eli View Post
Hi There
Thank you so much
I have a similar problem, I want to set a BC on a complex 3D wall for my additional variable that looks like:
V*C-D*dC/dn = k*C,
where V, D and k are constants and C is my additional variable. The problem is how to calculate the dC/dn as it is the gradient in the normal direction from the wall. Any suggestions?
Lance is offline   Reply With Quote
Old   January 13, 2011, 16:53
Will the CEL variables normal, with extensions like _Coordinate_Direction help you? See the CFX reference guide, "Quantitative CEL functions in CFX"
Old   January 14, 2011, 04:56
Lance
Yes, maybe. In POST I calculated the gradient of my AV in the Variables tab, so that I got AV.Gradient X, AV.Gradient y, and AV.Gradient Z. Then I made an expression: AV.Gradient X*Normal X+ AV.Gradient Y*Normal Y+AV.Gradient Z*Normal Z. Is this be the same as Av.Gradient Normal?
And can I define AV.Gradient X (...etc) in PRE as well?
And btw, how do I define the boundary condition at the wall? The units resolve to [kg/(s m^2)]. Transfer coefficient+additional variable or Flux in?
Additional variable John CFX 2 October 16, 2008 05:33
Problems with additional variable Krishna Premi CFX 1 October 29, 2007 08:19
Additional Variable - Diffusive Transport Equation RadheShyam Das CFX 3 October 18, 2007 12:35
Multi_component Vs Additional Variable Anurag CFX 2 February 4, 2005 16:45
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
