Analysis of flow around cylinder (2D)
Old   September 30, 2010, 13:28
Wink Analysis of flow around cylinder (2D)
kate
katiyon is on a distinguished road
Send a message via Yahoo to katiyon Send a message via Skype™ to katiyon
has anyone obtained valid hydrodynamic characteristics (Cd, Cl, St number) of a flow around circular cylinder in low Reynolds (10 -40 ) regimes by CFX? i have a 2D model and there are a lot of things that are influence on result. such as domain size and ... i cant find all
katiyon is offline   Reply With Quote
Old   September 30, 2010, 14:17
Joshua Counsil
Josh is on a distinguished road
Hi Kate -
I performed a CFD analysis on a cylinder back when I was new to CFD. Naturally, the results weren't great because there were many things I didn't consider.
Two of the most important factors to consider are grid resolution (i.e., the solution doesn't change with further refinement) and grid quality (i.e., grid factors separate from resolution that affect simulation convergence). Spalart (Young-Person's Guide..., 2001) had a beautiful example of a well-resolved, high-quality grid for a cylinder. It's built for a DES simulation, but it largely encompasses the same considerations:
Avoid the overlap regions, if possible. Notice how the orthogonality, aspect ratio, skew, and other parameters are very high in quality in both the cylinder's immediate region and wake region.
Other factors are considered here:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
At that Reynolds number, you will need a laminar, unsteady solution to capture shedding.
Josh is offline   Reply With Quote
Old   February 10, 2011, 16:07
Default Hi Josh,
Ugly Kid Joe
vmlxb6 is on a distinguished road
I am trying to simulate a flow over a cylinder. Its a 1 way FSI (moving mesh problem). Your mesh is very neatly made. I need a mesh like that but finding it hard to make one. Can you tell me which software did you use to create this mesh ??? Any tutorials available ???
vmlxb6 is offline   Reply With Quote
Old   February 10, 2011, 16:57
Josh included a reference in his post, that is where the mesh he showed came from.
Note the mesh is an overlaping grid. CFX does not support overlapping grids so this mesh would not be useable.
But there are hundreds of studies of flow over a cylinder in the literature using all sorts of different techniques. It is a standard benchmark simulation. Do a search of the literature and you should find lots of them.
Old   February 10, 2011, 19:31
Joshua Counsil
I agree with Glenn. Though CFX does not support an overlapping mesh, you can still create a nice O-grid in ICEM with downstream refinement.
Here is an ICEM tutorial for creating a C-grid around an airfoil. The techniques would be similar for a cylinder.
http://www.youtube.com/watch?v=tYrbScUH9RE
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 10:05
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Flow past 2 smooth circular cylinder slip FLUENT 0 July 8, 2010 18:45
In cylinder flow analysis Venkatesh V Main CFD Forum 2 November 29, 2006 08:03
