Assessment parameter for a flow process
Old   February 18, 2011, 08:35
Default Assessment parameter for a flow process
rskrishna87 is on a distinguished road
Hi everyone,
Mine is a Cooling chamber model with impingement jetswith arrays of jets in span-wise and stream wise direction. and the purpose of my model is to remove the heat from the metal surface and also for the film cooling on the turbine blades.So right nwo we are monitoring Temperature of the Solid. I also want to know which way is the best to monitor and predict also the amount of air flow into the model?
rskrishna87 is offline   Reply With Quote
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
Parameter Set Problem /Fluid Flow Paul_Re CFX 0 December 4, 2010 14:01
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
How can I process the temperal flow of Star-CD? Miles Siemens 1 October 31, 2002 05:39
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
