HP MPI warning...Distributed parallel processing |
February 5, 2008, 13:21 |
Hi I want to use HP MPI scheme for distributed parallel processing. I use following command script.
root/cfx5solve -def *.def -ini *.res -double -par-dist $NODES -start-method "HP MPI Distributed Parallel" -size-part 4.0 But it gives me following warning. Could any body suggest some solution. Thanks. ***************************Warning**************** ******** Warning ! The current start method, HP MPI Distributed Parallel, is not a standard PVM parallel start method, and so the parallel option cannot be changed independently to Distributed Parallel. Request ignored. If you are using both -start-method and -par-local or -par-dist on the command line, you can move the -start-method switch to after the -par-* switch. |
February 5, 2008, 13:39 |
Re: HP MPI warning...Distributed parallel processi
Hi Peter,
I get that warning too, but I generally ignore it. My cases always run on the correct nodes using the solver-hpmpi executable so I figured it was fine. Are your cases not running appropriately? -Alex |
February 5, 2008, 13:52 |
Hi Alex,
Though the command '-start-method "HP MPI Distributed Parallel"' gives warning but the correct number of nodes are allocated to my simulation. Simulation goes well. I also have been ignoring this warning but wanted to discuss view of other people. By the way, is solver-hpmpi a different executable? What does it mean? -Peter |
February 5, 2008, 17:09 |
When you run CFX it chooses a different executable depending on whether it is a serial or parallel run, and which mpi libraries are utilized. I might not be stating this exactly correctly (I am no software engineer), but basically the executable depends on which libraries were included in compiling the code and are therefore necessary to run the code in this configuration. A serial run uses solver-pvm.exe, hp mpi runs use solver-hpmpi.exe, etc. Even if you get this message, it doesn't seem to matter since the correct nodes are running the hp mpi executable. That's pretty much everything I know about it. I go with the "If it ain't broke, don't fix it" philosophy on this one.
February 5, 2008, 17:19 |
Thank you very much Alex. I also agree with your philosophy. Your reply is full of useful information and I will try to understand it with the help of my friends who are rich in computer's knowledge.
January 3, 2010, 13:57 |
h-h
Rep Power: 16 |
hi
excuse me for my english. I have a problem to use "hp mpi" in windows xp x64. I use ansys help to install the servise but it dosent work. in cfx>tools>command type "cfx5parallel -install-hpmpi-service" and it installed then type "cfx5parallel -register-hpmpi-user" then it want password, after enter password this error is showing "mpid: cannot conect to mpirun". can i use hp mpi in local machin whit multi processor? i can install and use mpich2 but system restart is always occur. |
February 8, 2010, 09:56 |
#7 | |
Rep Power: 17 |
February 8, 2010, 17:07 |
Rep Power: 143 |
HP-MPI works fine for me. I just followed the instructions in the documentation. If you have read the trouble shooting section in the manual and it does not help then will have to contact CFX support.
February 8, 2010, 18:17 |
#9 |
h-h
Rep Power: 16 |
finally i install hp mpi.i just make a virtual network and using ansys help.
my computer restart was from my mainboard(ma790x-ds4). the "isl" of mainboard power was failed. i repaired it three time but finally i had to buy a new one(ma790gp-ud4h). |
May 13, 2011, 10:02 |
hp mpi not installing on wind 7 64 bit Ansys CFX
#10 |
david malins
Dear all,
I've installed CFX 13 but I try and install the hpmpi service and it gives the following error, without getting into the install. It can't get the registry so I'm assuming it's something up with my OS. Has anyone got any ideas? much appreciate the help dave |
May 14, 2011, 06:17 |
#11 |
Rep Power: 143 |
Are you sure you are installing as admin? If you cannot write to the registry you will get error messages like that.
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
