April 30, 2024, 05:13 |
BVM Combustion Modelling, Flamelet Library
Bishwajit Nandi
Rep Power: 2 |
I wanted to simulate deflagration model
I imported Methane Air FLL STP and NO PDF from reaction library. I used k-omega as the turbulence model and BVM as the combustion model and while selecting the above flamelet library file a warning appears as follows: Reaction 'Methane Air FLL STP': The specified Flamelet Library file cannot be opened. Please check that the file path is correct and that the file exists. When I open the file from the reaction the following warning appears as: The flamelet file has been provided is not valid. Please check that this file is correct type and is not corrupt. I am using Ansys 2024 R1 student version. |
bvm, explosion, flamelet library, flamelet model |
Flamelet library | HurricaneHenry | CFX | 2 | April 30, 2024 04:51 |
modelling combustion in micro gas turbine | zackufairu | ANSYS | 0 | April 10, 2015 02:33 |
Combustion modelling results accuracies | Les | Main CFD Forum | 7 | June 1, 2011 08:55 |
combustion modelling books | swamysrikanth | Main CFD Forum | 3 | May 5, 2011 02:57 |
user defined nox flamelet library | narak | STAR-CCM+ | 0 | November 7, 2009 13:46 |
