CFX ERROR : unable to write the requested IO string array data set.
Like Tree3Likes
  • 3 Post By HJH
Old   March 16, 2016, 01:22
Default CFX ERROR : unable to write the requested IO string array data set.
HJH
Jeonghee
HJH is on a distinguished road
I am facing an error trying to write a solver input file as follows:
Error
A problem was encountered with a CFX data file.
Unable to write the requested IO string array data set.
What = G/CLBSF
Where =ZN1
When =0
Primary file =E:\HJH\SMART-CTMT\sn0311.def[open]
Any help is welcomed. Thank you.
HJH is offline   Reply With Quote
Old   March 17, 2016, 03:35
monkey1 is on a distinguished road
Are you sure that your disc is not full?
And "Primary file =E:\HJH\SMART-CTMT\sn0311.def[open]" could make reference to the fact that your sn0311.def is open in another program and therefore not overwriteable?
That would be my guesses.
monkey1 is offline   Reply With Quote
Old   March 17, 2016, 20:26
It is not a very helpful error message, is it?
Something is wrong with your setup. I am guessing here, but are you linking to external files? Do you have a material property defined using a lookup table? I am guessing these sort of issues could cause that error.
Old   March 18, 2016, 03:14
Smile This error..
HJH
Jeonghee
I've found the answer, and finally succeeded in writing the solver input file.
This error was caused by the long name of some boundary region.
I've set very long name on a primitive region.
That's why solver input file could not be written.
Thanks!!
monkey1, FarhanAhmed and -Maxim- like this.
error io string array
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Importing 3D data as CEL into ANSYS CFX 11.0 Dave W. CFX 9 October 19, 2007 08:18
Porous Flow and Data CFX 4.4 Robin CFX 0 April 14, 2005 09:56
How to make data file for matlab from CFX? cfxbeginner CFX 4 October 19, 2002 07:56
