April 30, 2011, 20:55 |
Anyone ready to help me!!!!
abishai murday
Rep Power: 15 |
Hi everyone
I am basically trying to a simulate a wing in and out of the ground effect on Ansys workbench. I have been trying hard but i cant get to set up the simulation, i am still a beginner. Is there anyone out there good in ansys who could help me set it up..i am kinda desperate.... its for my ind project deadline in 10 days!!!...i would really appreciate.... my email is Abishaimurday@yahoo.co.uk.... thxxx Abishai |
May 1, 2011, 15:29 |
Hey friend give us more information in order to know if we can help you!!
May 1, 2011, 17:23 |
abishai murday
Rep Power: 15 |
hey juliom
thanks 4 ure reply man!......basically i would like to simulate the vortices of a NACA 0015(c=15.2cm and b=73cm) out of ground effect and show its decrease in ground effect. I performed some wind tunnel tests and want to compare my results... i have already done my meshing....and i was told by my supervisor the best turbulence model is the K-W model. I haven't been taught the technical stuff about cfd...so im finding the set up a bit hard.....i was hoping someone could help me.... thanks |
May 1, 2011, 17:33 |
man,K-E will not suit to your model since there you have a boudnary separation and a adverse pressure gradiente, as a result you will need to define as a turbulence model the SST model
greetings |
May 1, 2011, 17:38 |
abishai murday
Rep Power: 15 |
is there anyway you could help me set it up!!!!if its not askin to much......would really appreciate.....
May 2, 2011, 08:56 |
Well I have not work with airfoils, but I have a toturial wich explain how to setup the boundaries conditions for an airfoil but in supersonic condition, let me try to send it to you.
In the other case, you can send the case to me, and then I will define the boundaries conditions. Juliocesarmendez.carvajal@gmail.com |
FixedGradient Boundary Condition | shrina | OpenFOAM Running, Solving & CFD | 4 | August 22, 2019 11:08 |
Interpolation between faces and points of a polyPatch | hartinger | OpenFOAM Running, Solving & CFD | 12 | March 7, 2016 13:08 |
[Commercial meshers] Harpoon to Foam | Manuel Garcia (Garcia) | OpenFOAM Meshing & Mesh Conversion | 58 | March 25, 2008 18:38 |
Multiphysics Engineer Ready to Change History? | BE | Main CFD Forum | 16 | August 11, 2007 14:28 |
Poly2Tri is ready for download from this weekend. | Liang, Wu | Main CFD Forum | 8 | November 15, 2005 11:42 |
