calculate Strouhal number
Like Tree2Likes
  • 1 Post By omidiut
  • 1 Post By ojha.mayank485
Old   May 22, 2011, 03:38
Default calculate Strouhal number
omid
omidiut is on a distinguished road
Hi all
I am solving a turbulence flow around a bluff body, using DES model.
How can i calculate strouhal number for it?
Best regards
EL OMARI Achraf likes this.
omidiut is offline   Reply With Quote
Old   May 24, 2011, 00:08
ojha.mayank485's Avatar
Mayank Ojha
ojha.mayank485 is on a distinguished road
Find the values of coefficient of lift for the body at different time values and do a FFT (fast fourier transform). Excel or even Matlab have built in functions to perform FFT. That will give you the frequency of vortex shedding (f).
For a cylinder St=f*D/U, for any bluff body I do not have any idea. You may look up literature.
Hope that helps.
-Mayank
samik108 likes this.
ojha.mayank485 is offline   Reply With Quote
Old   May 24, 2011, 02:04
omid
Thanks ojha.mayank485
can time step size effect the frequency?
Old   May 24, 2011, 07:39
Yes. Time step size is one of many parameters you will need to check to get an accurate simulation http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   May 24, 2011, 13:52
Default @Omiduit
Mayank Ojha
Your timestep size should be smal enough to predict the flow properties accurately. For example if you monitoring the vortex shedding, then use time step atleast 1 to 2 % of vortex shedding period.
BTW what bluff body are you using ???
Old   August 14, 2016, 17:06
Sathish
pssk1988 is on a distinguished road
I would like to add clarity. In general, the vortex shedding period is very large compared to the simulation timestep (considering time-explicit schemes).But here's the actual constraint: The timestep must be smaller than the vortex shedding period, mainly to avoid Aliasing effect. Read: https://en.wikipedia.org/wiki/Aliasing
To avoid aliasing, the sampling frequency must be greater than f/2, where f is the measured signal frequency. Therefore, maintaining atleast 3 measuring points per shedding period captures frequency information. However, more the data points better the shedding frequency captured.
pssk1988 is offline   Reply With Quote
Old   August 31, 2020, 14:18
Joćo
JoaoRoque is on a distinguished road
Hi
I'm not able to calculate the Strouhal number using the FFT on excel.
I'm following the instructions on the following file, being the data, the CL values, but I obtain a shedding frequency of 849 Hz for a Re of 40 (d=1.5 mm, U=0,4m/s, air kinematic viscosity), which is absurd.
Can someone pls tell me what am I doing wrong?
Thanks in advance!
JoaoRoque is offline   Reply With Quote
Old   August 31, 2020, 18:36
How can we tell you what you are doing wrong when you don't show us your simulation or the excel file?
So ask your self these questions:
Is the simulation accurate? This FAQ can help: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
Are you calculating the FFT correctly? You should not use excel for any serious numerical work. You will go a lot further with a package designed for serious work, like matlab, python or something like that. But to check if your FFT is working then look at the most obvious frequency in your signal and work out the approximate frequency by hand and compare to FFT.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   September 1, 2020, 02:18
Joćo
I can't show you the simulation files, because I have not been able to charge the PC which I ran it with. But here are the excel files and some information about the simulations:
Inlet is 5d away from the cylinder center, outlet is 25d, being d the cylinder diameter
top and bottom are 10d away from the cylinder center
73800 cells, I checked the mesh and it seemed good in terms of structure
i ran pimpleFoam in piso mode, with turbulence off. I ran pimpleFoam because of the fact that it has the ability to adjust the time step to guarantee the Courant number doesn't get higher than specified (1, in my case)
boudary types are patch on inlet, outlet, top and bottom, noSlip on the cylinder.
Excel files
https://drive.google.com/file/d/1g6y...ew?usp=sharing
https://drive.google.com/file/d/1b6a...ew?usp=sharing
Old   September 1, 2020, 02:31
karachun's Avatar
karachun is on a distinguished road
This is Ansys CFX forum, not OpenFoam forum. Please post OpenFoam questions here.
https://www.cfd-online.com/Forums/openfoam/
karachun is offline   Reply With Quote
Strouhal number ? Tony Chen Main CFD Forum 10 February 1, 2013 13:05
Strouhal number in FloWorks Akceptor FloEFD, FloWorks & FloTHERM 1 September 1, 2010 03:43
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
How to calculate Nusselt number SeRGeiSarov Main CFD Forum 4 May 6, 2009 01:57
Strouhal number ar FLUENT 0 June 8, 2006 04:04
