May 24, 2011, 23:06 |
newer version of Fluent/ CFX Vs. CFX11?!?
mohammad
Rep Power: 16 |
Hey;
I'm simulating the NREL wind turbine model with CFX11 but I want to use a newer version of Fluent/CFX. At this stage, my plan is to investigate the different turbulent models( DES, SST, SA) and transitional flow. I have some questions now. 1- I read the REF[1] about a transitional model and its better prediction of wind turbine performance. which software and which version ( Fluent or CFX) has this model ? 2-Do you have any information about the advantages of the newer versions of CFX/Fluent or over CFX 11 about the use of turbulent models? is there any newer turbulent option or influential modification available in newer versions of CFX/Fluent that can really affect the results? Reference [1]-Predicting 2D Airfoil and 3D Wind Turbine Rotor Performance using a Transition Model for General CFD Codes; R.B. Langtry, J. Gola, and F.R. Menter , AIAA; 2006 |
May 26, 2011, 03:13 |
mohammad
Rep Power: 16 |
It's available. for more info see the following link...
http://www.cfd-online.com/Forums/cfx...tml#post309290 Good Luck |
May 26, 2011, 06:41 |
Rep Power: 143 |
CFX has the transition model. Not sure about Fluent, I think V13 has it but I am not sure.
The reference you quote is an excellent one, it shows the benefits of the turbulence transition model in CFX. I think this is a strong argument to use the turbulence transition model in CFX as that paper shows it works well. It will hopefully also give you some tips of how to implement it properly. |
May 26, 2011, 09:38 |
#4 | |
mohammad
Rep Power: 16 |
it says that: Turbulence has been an area with active sharing between the FLUENT and CFX functional groups.Turbulent transition modeling is available in FLUENT 12. |
cfx13, new fluent, vs. cfx11 |
Mesh and Solve Times for CFX, Fluent, CD-adapco | Jade M | Main CFD Forum | 4 | August 28, 2012 02:54 |
Import CFX def into Fluent | eric_wang | FLUENT | 0 | April 18, 2011 13:14 |
Reynolds Stress Model in Fluent Vs CFX | Tim | FLUENT | 0 | December 6, 2005 22:03 |
CFX compared to FLUENT | newbie | CFX | 1 | August 1, 2005 18:29 |
Fluent or CFX? - strenghts, weaknesses? | Riaan | FLUENT | 0 | June 27, 2005 15:25 |
