Prescribed mesh motion does not correspond to actual motion
Old   June 21, 2011, 05:55
Default Prescribed mesh motion does not correspond to actual motion
Richard Barrett
rbarrett is on a distinguished road
Hi, I am attempting to simulate the compression of a gas within a piston-cylinder apparatus using Ansys CFX. I am using CEL expressions to specify the mesh motion, coupled together with the 'Specified Displacement' option. I am applying the mesh motion to a subdomain of the main fluid domain and I am finding that the results of the simulation do not match the prescribed motion that I have applied through the CEL expressions, i.e. the CFX simulation lags behind the actual.
I was just wondering if it is correct to apply this type of mesh motion in this manner and if so, why do my results lag behind the prescribed motion.
Thanks in advance
Regards
Richard
rbarrett is offline   Reply With Quote
Old   June 21, 2011, 08:34
stumpy is on a distinguished road
This means you've set something up wrong. Could you post the expressions used and the relevant CCL for the subdomain and boundary conditions?
stumpy is offline   Reply With Quote
Old   June 21, 2011, 09:26
Richard Barrett
Thanks a million for your reply and apologies for the length of my reply.
I am attempting to model the compression of two opposed pistons in one cylinder, hence there is a line of symmetry down the centre of the combustion chamber and the model is axisymmetric about the central axis. Initially the cylinder is 178 mm and the stroke length is 167.81 mm. Included below are the CEL expressions used in this simulation. Note that anything to do with 'Function' are step functions used to define different phases of the compression, i.e. acceleration, CV and deceleration stages and I have omitted these CEL expressions.
Also included is an image of the desired displacement function that I wish to apply as the mesh motion. This is applied to a subdomain which comprises of the full fluid domain and the function drops off linearly to zero at the mid chamber location (as there is zero mesh motion at this location). The BC's used in this simulation are all either wall or symmetry BC's, all with 'unspecified' mesh motion as mesh motion is dependent on the motion of the subdomain.
Disp = OverallFunction*sDisp
TDC = 167.81e-03 [m]
TotalTime = 116.6e-03 [s]
aAccel = 2079.05 [m/s^2]
aDecel = -23493.3 [m/s^2]
sDisp = sDispAccel+sDispCV+sDispDecel+sDispZero
sDispAccel = (0.5*aAccel*t*t)*Function1
sDispCV = ((velCV*t)-(0.5*aAccel*tAccel*tAccel))*Function2
sDispDecel =
(((t-timeDecel)*(velCV))+(0.5*aDecel*(t-timeDecel)*(t-timeDecel))+((velCV*timeDecel)-(0.5*aAccel*tAccel*tAccel)))*Function3
sDispZero = TDC*Function4
tAccel = 6.07055e-03 [s]
tCV = 9.992233e-03 [s]
tTotal = 16.6e-03 [s]
timeDecel = tAccel+tCV
velCV = 12.621 [m/s]
Old   June 21, 2011, 09:42
So 'Disp' is the function applied to the subdomain, with 'OverallFunction' providing the linear weighting? Since this appears to only depend on t (and x/y/z to get the linear weighting I assume), then the results should be fairly easy to debug. In your results file you can get the "Total Mesh Displacement" at one end of the cylinder. Given t and x/y/z at that location you can evaluate your displacement expression. Are you saying these two don't match?
Old   June 21, 2011, 10:07
Richard Barrett
Thanks for your reply and yes, 'Disp' is the desired displacement function and applied as the mesh motion to the subdomain. As is shown in the graph above, the applied total displacement is 167.81 mm at the end of the cylinder exposed to the maximum displacement. From the results file, the 'Total Mesh Displacement' at this end of the cylinder is only 91.72 mm.
Old   June 21, 2011, 13:48
What is OverallFunction equal to? If it depends on x/y/z did you account for the fact that x/y/z will change during the solution as the mesh moves?
Old   June 21, 2011, 15:26
Richard Barrett
The two variables that every CEL expression depends on are 't' and 'aaxis'.... Does the 'aaxis' variable change as mesh deformation occurs?
Old   June 21, 2011, 16:35
aaxis is usually just equal to z, unless you have some local coord frame defined. So if the mesh moves in the z direction then yes, aaxis will change.
Old   June 30, 2011, 13:22
Richard Barrett
Thanks a million for your help.
Negative Volume during Mesh Motion Analysis giov_ingr FLUENT 2 December 13, 2013 06:09
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 10:04
a mesh motion question womo CFX 5 March 16, 2011 10:54
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
mesh motion samad87 FLUENT 0 August 6, 2009 03:15
