How should I plot dv/dt in CFX?
Like Tree3Likes
  • 1 Post By alemarins
  • 2 Post By alemarins
Old   December 30, 2011, 00:31
Default How should I plot dv/dt in CFX?
Ali
ali8500 is on a distinguished road
Hi Guys,
Does anyone know How I can plot dv/dt in CFX where v is velocity and t is time?? I want to see the change of this term at specific time for my 2d simulation. I like to have a contour showing the changes of dv/dt.
Thanks,
Ali
ali8500 is offline   Reply With Quote
Old   December 30, 2011, 03:35
Smile
alemarins is on a distinguished road
Time derivatives are partially supported in CEL.
Velocity time derivatives can be accessed with the ".Time Derivative" operator by setting up an additional variable as follows:
ADDITIONAL VARIABLE: utderiv
Option = Vector Algebraic Equation
Vector xValue = u.Time Derivative
Vector yValue = v.Time Derivative
Vector zValue = w.Time Derivative
END
Saeef likes this.
alemarins is offline   Reply With Quote
Old   December 30, 2011, 03:41
Ali
Thanks for your response.
What is utderiv? do I need to define a new variable named utderiv?
I've started using CFX recentley. could you please explain more about the code?
tnx
Old   December 30, 2011, 08:57
utderiv is the name of the vector variable with du/dt, dv/dt, and dw/dt components.
This way could be simpler for you:
1) from CFX-Pre GUI define a new Additional Variable named "utderiv" (or whatever you like)
2) in the panel select: Variable Type = Unspecified; Units [m s^-2]; Tensor Type = Vector
3) go to Domain->Fluid Models->Additional Variable Models and select "utderiv" in the selection area
4) flag the check-box just below the selection area
5) type "u.Time Derivative" in Vector xValue, and so on.
doublestrong and Saeef like this.
Old   December 30, 2011, 10:55
Lance
Lance is on a distinguished road
huh, I had no idea you could do that.
Reading a bit in cfx_ref.pdf I also found .Magnitude, .Gradient, .Curl, .Laplacian among others. Do they also work like .Time Derivative on AVs?
Lance is offline   Reply With Quote
Old   December 30, 2011, 14:47
Ali
Thank you so much Alemarins.
I have two more questions. In Vector-xvalue box I have to enter u.Time Derivative or Velocity u.Time Derivative???
My second question: It seems that I have to run my simulation again so as to get the results for my new variable right? since I've already run my simulation is there any way to find du/dt in CFD-post?
Thank you for your help
Old   December 30, 2011, 16:12
Ali
I got the answer for my first question. As you said u.Time Derivative works. I'm just curious to find a way so as to plot du/dt in CFD-post.
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 07:08
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
