February 6, 2012, 13:04 |
species transport
Cecília Mageski
Rep Power: 14 |
Hello
I need simulated a species transport. Oxygen in water, with mass fraction and diffusion coefficient, but i don't know how to do. |
February 6, 2012, 19:01 |
Rep Power: 143 |
Have you done the tutorials on additional variables, multicomponent and multiphase flows?
February 7, 2012, 08:04 |
Cecília Mageski
Rep Power: 14 |
Yes, for multicomponent. But when I put the mass fraction of oxygen as multicomponent, the oxygen disappear in my geometry from one position. My geometry is followed by a contraction and expansion after expansion there is no oxygen in the fluid. I wonder if the CFX imposes zero mass fraction at the exit.
For additional variable, i din't understand very well the what is and din't found what tutorial . Send the name of tutorial this part talk about this exactly. |
February 7, 2012, 16:16 |
Rep Power: 143 |
Can you describe what you are modelling? What is the oxygen doing in the water?
February 8, 2012, 07:23 |
Cecília Mageski
Rep Power: 14 |
yes of course. I transporting oxygen through the water to find the concentration close to the wall and to estimate the corrosion according to the concentration of oxygen near the wall. but when using multicomponent transport oxygen after expansion tends to zero, oxygen is not the entire flow. The water have a saturation of the oxygen em mg/L free in water, and the oxygen a coefficient diffusion in water.
February 8, 2012, 07:24 |
Cecília Mageski
Rep Power: 14 |
February 8, 2012, 16:44 |
Rep Power: 143 |
I would consider using an additional variable rather than a multi component mixture. Multi component mixtures are designed for multi-component gases, not gases dissolved in liquids.
February 9, 2012, 11:12 |
Cecília Mageski
Rep Power: 14 |
Ok thank you. I will test.
February 15, 2012, 05:08 |
wall permeability in species transport
#9 |
anonymous
Hi all,
I want to find the concentration distribution of a species in a region. The model has two zones. The distribution is being calculated in single zone only. How to include the permeability of the wall in between so that we can find the species distribution in the other zone also. Thanks for your help. |
February 15, 2012, 05:27 |
#10 |
Rep Power: 143 |
Make the porous wall an interface and put a resistance coefficient on it.
#11 |
Rep Power: 14 |
Hi cfdplayer!
If I got you right then you have 2 (connected) domains for your problem and you want the flow to go from one to the other? If this is your problem you must use / set up the domain interface. Chapter 13 in the cfx_pre.pdf help files of CFX. |
June 15, 2018, 17:33 |
#12 |
Paul Lee
Rep Power: 7 |
I'm also simulating aqueous galvanic corrosion in fluent and are wondering if the stock gas mixture material is a suitable approximation of ionic species in water. Additional variables sounds like a promising solution to tracking ionic movement. How do I add the additional variables? is there a tutorial on that? I did a quick search on ANSYS help but it seems all the tutorial on additional variables is for CFX and not fluent.
June 16, 2018, 05:03 |
#13 |
Rep Power: 143 |
Try the fluent forum.
Modelling Biomass Combustion via Species Transport | Racheal | FLUENT | 39 | January 8, 2022 07:42 |
Please help!! Patch and Species transport | Julie | FLUENT | 5 | August 3, 2016 03:10 |
questions about species transport through walls | shuqin | FLUENT | 13 | April 9, 2014 02:42 |
Questions for a species transport problems (snapshots attached) | aleisia | FLUENT | 2 | October 9, 2011 04:40 |
species transport in water | lyn | FLUENT | 1 | December 12, 2007 18:15 |
