February 20, 2012, 00:15 |
problem in convergence
Shashwat
Rep Power: 14 |
Dear friend
I am doing blood flow through stenosed artery. I consider the arterial wall as porous domain wall has multiple layers which has different porosity and permeability I have written permeabity and porosity as a function of r it is steady state analysis. I am facing the convergence problem .I need your help Thank you Regards Shashwat |
February 20, 2012, 00:52 |
Rep Power: 143 |
Use a much smaller timestep to start off, and possibly local time scale factor (set it to about 5). Run that for a while until it starts to converge, then switch back to physical time scale with a larger time step to convergence.
These are all standard tricks for getting convergence, read the documentaton on "Obtaining Convergence". |
convergence problem when use pisoFoam, LES for wind tunnel case | Forrest_Lei | OpenFOAM | 3 | July 19, 2011 06:00 |
convergence problem | commonyue | Main CFD Forum | 1 | December 1, 2009 03:54 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
3D Fluid Flow Convergence problem | Emily | FLUENT | 2 | March 21, 2007 22:18 |
Non Convergence of 3D Heat transfer cfd problem | Balraj | Main CFD Forum | 3 | December 9, 2004 00:24 |
