Home > Forums > Visualization & Post-Processing Software > EnSight
3D visualization help
Old   September 4, 2012, 19:10
Question 3D visualization help
Fabio
ftalves is on a distinguished road
Greetings.
I've been having severe difficulties getting the 3D mode ('stereo') to work on my projects.
I have a Quadro 4000 and am using NVIDIA's Vision 2 glasses, with the DIN-connected synchronizer. Also, I'm using an ASUS 3D monitor. My EnSight's version is 10.0.2(e).
On my most recent tries, either the stereo option remains greyed out or it shows the 'ghosts' intrinsic to 120Hz stereo 3D, but the glasses won't synchronize.
Any tips or thorough guides to make it work?
ftalves is offline   Reply With Quote
Old   September 4, 2012, 21:34
mjgraf is on a distinguished road
have you tried using a CRT that vsyncs at 120Hz?
also, double check that the nvidia drivers stereo mode.
also, consult with CEI support about your problem. They normally have a solution already or will help find a solution to your problem. If your maintenance is current ;-)
mjgraf is offline   Reply With Quote
Old   September 4, 2012, 21:45
Fabio
Thank you. I have no CRT monitors capable of 120Hz available to me right now, so I can't check that, but I have checked all drivers and such.
I have also contacted CEI in January about it, but they still haven't replied...
Is it supposed to be intuitive to turn it on (in which case I would be sure the problem is in my end)?
Old   September 4, 2012, 21:48
hmmmm. not sure.
I know the LCDs I have tried worked without much tinkering. But since they only did 60Hz were about useless.
My only thoughts at the moment are that it might be getting confused by the 3d display AND the stereo adapter being available.
Old   September 4, 2012, 21:50
Fabio
hmmmm. not sure.
Ok. I'll try and tinker some on the NVIDIA side of things.
Thanks for advices, anyway.
Old   September 4, 2012, 23:15
Fabio
I have found a workaround on the NVIDIA side of things.
It works on EnSight if I set the 3D to always show, as opposed to only function under 3D programs (in the NVIDIA Control Panel: Set up stereoscopic 3D -> Select when the display is in 3D mode).
Now, that means that my copy of EnSight does not appear to the system as a 3D application. Now the matter at hand is how to set EnSight up so the systems does see it as a 3D app.
ensight, how to, stereo
Visualization of higher order solution shyamdsundar Main CFD Forum 1 July 23, 2010 03:55
Visualization Software for CFD Paul Main CFD Forum 3 March 25, 2006 17:16
help: flow visualization library soofuu Main CFD Forum 3 September 28, 2000 10:54
CFX4-Interface for OpenDX Visualization Software? Doris Rieger Main CFD Forum 0 December 1, 1999 06:41
Flow Visualization of impinging swirling flow on the wall. sangaria Main CFD Forum 2 March 26, 1999 13:31
