Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Simulation of mixing
Old   October 27, 2008, 09:09
Default Simulation of mixing
Matic Grom
Hi everyone.
I have the following problem. I would like to simulate mixing of ethanol and water in cilindrical vessel. This would be unsteady (transient) simulation. At t=0 ethanol is on upper half of vessel and water at lower.
I have FloWorks simulation package. Is this kind of simulation at all possible in FloWorks? If it is, how to define initial conditions and specify two regions of vessel (one with ethanol and one with water?
I succesfully simulated mixing of ethanol and water in a sort of static mixer, but this was steady state simulation.
Thank you and best regards.
Old   October 29, 2008, 07:54
Default Re: Simulation of mixing
Dr. Dergunov
Hi!
You should do the following to solve your problem.
1. Create cylinder volume where ethanol would be placed at t=0. 2. Go to Flow Simulation>component control then select and disable the this volume for flow. 3. Go to Menu Flow Simulation>component control>Insert>Local Initial Conditions and set the Initial concentrations for ethanol. 4. Repeat this steps for water.
Old   November 11, 2008, 02:38
Matic Grom
Dear Dr. Dergunov,
I am very sorry for my late response, I was very busy last three weeks. I tried your suggestion and it worked.
Thank you very much.
Best regards,
Matic Grom
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
Simulation of mixing of two compressible fluids shinde.gopal OpenFOAM 1 September 7, 2010 09:37
mixing quality simulation harry CFX 5 May 8, 2010 14:36
Simulation of mixing of two compressible fluids shinde.gopal Main CFD Forum 0 December 10, 2009 04:08
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 13:46
