Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Flow Simulation Crash with Trajectories
Old   June 30, 2009, 15:36
Default Flow Simulation Crash with Trajectories
D.Castle is on a distinguished road
Hello again,
This question is more of a curiosity for me than anything else. I have a lot of problems with SolidWorks and Flow Simulation crashing when I try to insert a Flow Trajectory into the model. About half the time it works just fine, but other times the program wants no part of it. Does anyone else have this problem? Are there certain conditions which make it more likely to crash?
If anyone else has this problem, I'd love to know.
D.Castle is offline   Reply With Quote
Old   July 13, 2009, 04:14
Default Floworks Crashing
Matt Hieatt
Matt.Hieatt is on a distinguished road
Hello
I am not a technical support person and I work for Mentor so we dont officially support FloWorks - but this problem sometimes happens with FloEFD and when it does it is generally thought to be some form of conflict with your graphics card. If you try turning down the acceleration on the card it may help.
Matt.Hieatt is offline   Reply With Quote
Old   August 5, 2009, 14:50
murat
murat is on a distinguished road
Number of emit points causes the problem. You can decrase your number of lines or arrows.
Another is may be you works wrong variables. For example if you do heat transfer analysis and you want to create streamlines and you don't switch from solid temperature to fluid temperature, Floworks crashs.
murat is offline   Reply With Quote
Channel flow setup in Large-eddy simulation Weihua Main CFD Forum 6 November 17, 2015 09:33
Incompressible to compressible flow simulation Nishikant Tamrakar FLUENT 10 June 16, 2009 21:09
Stratified Oil-water Flow simulation Mijail FLUENT 2 May 18, 2009 20:20
Compressible Flow Simulation - business jet Tyler FLUENT 0 March 13, 2009 14:47
2D Flow Simulation Sethu Raghavan Main CFD Forum 0 October 18, 2001 01:12
