Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Zero Fluid Volume
Old   July 15, 2011, 15:51
Default Zero Fluid Volume
Gene G
GeneG is on a distinguished road
Hello, I am using EFDLAB 8. After bringing my model (STEP) and running Geometry check, I am getting good numbers (different from zero). After applying all the conditions and assigning all the parameters, system refuses to run my analysis and running geometry check again gives me a zero fluid volume.
I checking interferences, I found none.
Any leads? Thanks
GeneG is offline   Reply With Quote
Old   August 1, 2011, 08:01
Disabled
Boris_M will become famous soon enough
Hi Gene,
if you run ther check geometry before you ran the wizard to setup a project then you might have used it for external analysis if there was a gap somewhere and if you then define internal analysis in the wizard then you won't find a fluid volume if there is a gap so the model is not water tight. Try to switch from internal back to external and see if you find a fluid volume. This is a very good indicator to distinguish between invalid contacts and a not water tight model.
If you have invalid contact, neither internal nor external check will find a fluid volume. If there is a gap somewhere in you model you will find a fluid volume only in an external case as the model is not water tight for internal case it cannot find a enclosed cavity.
I hope this helps,
Boris
Boris_M is offline   Reply With Quote
There is no fluid volume in the project Giron FloEFD, FloWorks & FloTHERM 5 December 30, 2022 08:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
fluid hot volume in fluid cold volume zahid FLUENT 4 June 1, 2002 09:11
