Home > Forums > Software User Forums > FLOW-3D
Simulatling Two-fluid models..?
Old   May 27, 2012, 10:04
Exclamation Simulatling Two-fluid models..?
Mahdiar Farhoudi
mf_emp is on a distinguished road
I wanna simulate 3-sided spillway (U-shaped spillway) model using two-fluid.
Due to the Help menu:
CUSTOM TUTORIALS > Hydraulics Tutorial > Variation: Run as a Two-Fluid Problem
that say's when the two fluid densities vary by a significant amount, a two-fluid model is not accurate!
so how can i simulate my problem?!
Note: The model is highly turbulent.
mf_emp is offline   Reply With Quote
Old   May 27, 2012, 18:03
michael barkhudarov
MuxaB is on a distinguished road
Should be ok - have you tried already?
MuxaB is offline   Reply With Quote
Old   May 28, 2012, 06:48
Mahdiar Farhoudi
yes i tried it, but i didn't get correct outputs.
as it say, densities vary by a significant amount.
The primary problem here is that there is only one (mixture) velocity calculated at each cell face. In reality, because the densities are so different for the two different fluids, there is significant discrepancy between the velocity of the air and the velocity of the water. When the densities of the two fluids differ greatly, i.e., roughly by more than a factor of 10, this mixture velocity may not adequately represent the flow, since velocities of each of the fluids in the same cell can be very different.
did anyone Run such a two-fluid case with air & water??
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
What is the total energy for incompressible fluid? Harry Dong Main CFD Forum 12 February 4, 2006 00:55
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
