Home > Forums > Software User Forums > FLOW-3D
How to simulate the temperature distribution in die casting
Old   October 24, 2012, 07:13
Smile How to simulate the temperature distribution in die casting
B zeng
Billdada is on a distinguished road
Hi everybody, I am new to the forum
I am simulating a gravity die casting in Flow3D. Does anybody can teach me how to set up the simulation to show the temperature distribution during the filling.
I loaded the die ad the liquid with the initial temperature, and activate the Heat Transfer in first order and uniform component temperature. however, there is nothing relate to the temperature in the result.
Billdada is offline   Reply With Quote
Old   November 27, 2012, 15:43
MC
melissa is on a distinguished road
Did you define the properties of the die such as thermal conductivity and density*specific heat? You will also need to define thermal conductivity and specific heat for the fluid as well.
To visualize you would select fluid fraction for iso-surface contour and temperature for color contour.
You may need to put a heat transfer coefficient as well under Surface properties of die/mold component. FLOW-3D will calculate one for you based on 1-D flow over a plate so you can try that first if not a good value to start with is 1000 in SI.
melissa is offline   Reply With Quote
die casting, temperature distribution
Car fire in an underground park - Simulate a temperature sensor psc3 Fluent UDF and Scheme Programming 9 June 9, 2014 06:16
Temperature distribution at Impeller core!> CFDtoy Main CFD Forum 5 May 14, 2007 09:06
maintaining a logarithmic velocity distribution Morten Andersen CFX 1 January 8, 2007 11:37
Linear Temperature Distribution Kathir FLUENT 0 July 16, 2004 09:33
Temperature Distribution on a circuit board Blackadder Main CFD Forum 1 March 27, 2003 11:32
