Home > Forums > Software User Forums > FLOW-3D
flow structure around cylinder
Like Tree2Likes
Old   January 17, 2013, 02:05
Default flow structure around cylinder
bird
pyxbird is on a distinguished road
Dear all,
As you can see in the picture, velocity=45cm/s, diameter=30cm, Re=13500, RNG model is used, the grid is fine enough, the flow is steady, usually in this condition the turbulence behind the cylinder should be intensive, vortices should be seen. However from the streamlines we can see that the model performs not so good, why?
Milad h likes this.
pyxbird is offline   Reply With Quote
Old   January 18, 2013, 08:24
Daniel
Davahue is on a distinguished road
Dear pyxbird,
I've done the same simulation: karman street vortex past a cylinder.
I did 2D with the same turbulence model. Can you specify wich is your grid spacement?
I'll recommend you to try with 2D with finner meshes and then go back 3D.
In my experience, FLOW-3D is able to catch the flow pattern past the cylinder even with other turbulence models.
Hope it helps,
Daniel
Davahue is offline   Reply With Quote
Old   January 19, 2013, 06:19
bird
Originally Posted by Davahue View Post
Dear pyxbird,
Hope it helps,
Daniel
Dear Daniel, thank you for your reply. In my model, the computation region is 5m long divided into 250 grids, 2m wide divided into 100 grids, 0.5m deep divided into 25 grids.
I will try your advice , if the problem exists, I will state it later, thanks.
Old   February 3, 2013, 00:11
bird
Dear pyxbird,
Hope it helps,
Daniel
Dear Daniel,
I have try with finner meshes in 2D, but it doesn't work. I will show you two pictures below. Did you see the problem?
Old   February 4, 2013, 04:58
Daniel
I still think that the mesh is too coarse, anyway, have you tried incresing the velocity? What happens then?
Originally Posted by pyxbird View Post
Dear Daniel,
Old   February 12, 2013, 13:56
mahdi
mahdi1 is on a distinguished road
Dear all,
Hello
Could you please tell me where can I introduce Reynolds number to software?
Thanks
mahdi1 is offline   Reply With Quote
Old   February 18, 2013, 23:24
Jay
jayrup is on a distinguished road
Dear all,
Hi pyxbird
Visually RNG model may not show you the vortices at this velocity.
But if you plot Fd & Fl around the cylinder you may observer the variation.
If you want to see visually the vortex shedding try to use LES model.
Regards
Jay
jayrup is offline   Reply With Quote
Old   March 7, 2013, 21:01
bird
It doesn't work.
Old   March 13, 2013, 01:36
Jay
It doesn't work.
Either the velocity is correct or the Re.
As per the velocity Re come 135000.
As per the Re velocity comes 4.5 cm/s
Try using Second order Monotonicity preserving for Momentum advection.
Well I do get the vortices with LES.
Please see the attached image.
Jay
Old   March 18, 2013, 06:30
bird
Jay
Dear Jay,
Hi, I have tried using second order monotonicity preserving for momentum advection, but it still doesn't work. The Re is 135000, 45cm/s, 50cm in depth. And I have tried the Tlen(mixing length) for 0.07*depth=3.5, and I have also tried Tlen for 10, 50, 300. The turbulence is not intensive.
So what might be wrong with my model? Or would you please show me some parameters of your model, some parameters that I probably set uncorrectly.
Old   March 28, 2013, 09:36
mahdi
Hello
I want to simulate flow around a cylinder.
Diameter of cylinder=0.0254 m , width of channel= 0.3048 m and U=0.9 m/s
my model:
No sharp interface, RNG, wall (no-slip), uniform mesh (cell size = 0.00635 m)
2 Dimension
X : inlet (velocity), outlet (continuative), Y: Wall, Z: symmetry
second order monotonicity, GMRES
There is difference between results of flow-3D and experimental results.
please see attached files.
Also, below message appear during running:
"there is no reference pressure"
Do you have an advice to solve it.
Thanks
Old   March 28, 2013, 20:42
bird
Originally Posted by mahdi1 View Post
Hello
my model:
2 Dimension
Thanks
Dear Mahdi1,
Hi, unfortunately I am not good at this part. RNG is used in your model, but I know that if LES is used, the velocity behind the cylinder will not be steady for ever so in that case you have to use time-averaged data to compare with the experiment data. By the way, where is the section?(what's the location of the velocity profile in x-direction?)
Last but not least, why can't I find any vortex in my model?
Old   March 28, 2013, 21:43
bird
Why? Still no vortex street, I am going to give up.........
Old   March 29, 2013, 06:17
mahdi
Hi
velocity values are in 16D downstream of cylinder.
I think that LES doesn't use in 2 dimensional problems.
about your model:
tell me your configuration of your model.
Old   March 29, 2013, 22:36
bird
Hi
about your model:
Cylinder D=10cm, water depth=50cm, cylinder height=25cm, inlet velocity=44.1cm/s,(developed, grid overlay is used) mesh: 2,200,000 grids ,y=80cm,x=200cm, RNG model
Old   March 30, 2013, 05:23
mahdi
Did you try to run your problem without Grid Overly?
Old   April 1, 2013, 06:55
mahdi
Hello Jay
Could you please tell me how I can plot fd (Drag Force) and fl(Lift)?
I want to calculate drag coefficient.
How can I calculate it by Flow-3D?
Thanks
Old   April 1, 2013, 20:36
bird
Yes, I do. But it makes no difference.
In 2D I can simulate vortex street now. However in 3D, it is not seen yet.
Old   April 3, 2013, 02:20
Jay
Hello Jay
Thanks
To calculate the Forces on component you need to enable the output for Component in Component properties we have an output option with Pressure & Shear force output.
In your case the Lift force will be component 1 y fluid force : Pressure + shear & Drag force will be component 1 x fluid force : Pressure + shear in Analyze tab > Probe Tab > General History in Flow-3d v10.1.Don't forget to define the gravity.
Regards
Jay
anuprdk likes this.
Old   April 3, 2013, 02:22
Jay
As per the image, it seems that your geometry is not properly resolved.
Can you send me your prepin file?
Regards
Jay
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 10:05
reference calcultion, flow around a cylinder butch85 Main CFD Forum 3 January 31, 2011 16:10
Flow induced vibration of a mobile cylinder Hooman Main CFD Forum 0 December 31, 2010 08:48
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
