Home > Forums > Software User Forums > FLOW-3D
Shear Stress
Like Tree1Likes
  • 1 Post By JBurnham
Old   October 10, 2013, 16:04
Default Shear Stress
Marcus Fernandes Araujo Filho
Marcus.filho is on a distinguished road
Dear all,
I´ve beeing try to evaluate the shear stress of a channel but i´ve found some issues. I´ve attached a picture of the results to help you guys to understand.
the problem is that it just doesn´t look right. The changes are very sudden and the values seem off chart. Does any have one have an idea of what might be happening?
My first thought is the my mesh is too course. Is there a "rule of thumb" of how dense should my mesh be in order to correctly estimate the shear stress? The mesh is around 0,5m in a 10m wide channel.
Thank you all.
Marcus.filho is offline   Reply With Quote
Old   October 17, 2013, 10:57
Jeff Burnham
JBurnham is on a distinguished road
Yes, Marcus, the shear stress output is mesh-size-dependent. Try halving your mesh size until the shear stress output doesn't vary by more than 3% between runs: you can call that the 'converged' mesh size. Also, please consider upgrading to v10.1 if you haven't already: the shear stress calculations are much better in v10.0 and v10.1 than in earlier versions. - Jeff
JBurnham is offline   Reply With Quote
Old   October 22, 2013, 08:03
Thank you Jeff!
One more question. Is there a "rule of thumb" of how many mesh cells must I have in a certain depth in order to have some first acceptable results?
Marcus
Old   October 22, 2013, 10:39
Jeff Burnham
Yes. The rules of thumb are:
1) at least 3 to 4 cells across the narrowest flow width (usually a depth, but might be a gate) in order to get a model that works.
2) at least 10 to 12 cells across the narrowest flow width to get a model that's accurate.
The best approach is still to start with rule #1 above and successively refine the mesh two or three more times (total of three or four meshes) and demonstrate that the difference between the finest mesh results and the next-closest mesh results are so small that the model can be considered 'converged'.
I know that's not always possible, so the rules of thumb above can be a shortcut.
Marcus.filho likes this.
Shear Stress Calculation in the flow. auburnuser FLOW-3D 11 May 12, 2018 13:49
Fluid wall shear stress Sinead Kelly (Kelly) OpenFOAM Running, Solving & CFD 2 March 30, 2011 06:41
shear stress scalar definitions? Novak Elliott CFX 0 April 6, 2003 01:45
WALL SHEAR STRESS Min-Hua Wang CFX 0 April 3, 2002 17:40
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 07:43
