Home > Forums > Software User Forums > FLOW-3D
void region and itb=0
Old   January 16, 2009, 06:51
Default void region and itb=0
ehsan
I need to simulate heat transfer in the system that don't have free surface and else i need to using void region. but with using itb=0 the void region will be full of fluid.
what should i do?
Thanks
Old   January 24, 2009, 12:54
Default Re: void region and itb=0
ehsan
My question have not answer?
Old   January 26, 2009, 11:53
HC
If there are fluid and void regions in the domain, it should NOT be set with the option "No free surface".
If the system is totally empty, meaning there is no fluid but void regions, you may still need to use the option "Free surface or sharp interface". As for the initial condition in this case, please just set the void regions and their types.
