Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
problem with inlet BC setting
Old   June 13, 2013, 11:31
Default problem with inlet BC setting
Tanjina Afrin
Tanjina is on a distinguished road
Hi all.
Currently I am working on a simple geometry with fluent where water will enter from static reservoir into pipe and air will replace the empty place of reservoir. I put pressure inlet. But it didn't give this type of result. Water is coming instead of air. Could anyone suggest me how can I set inlet BC for this type of phenomena?
I tried to put "air", "water" and "mixture" in pressure inlet ( I also tried with velocity inlet), but fluent says "this type of setting is not application for current setting" for air.
Tanjina is offline   Reply With Quote
Old   June 14, 2013, 10:33
OJ
oj.bulmer will become famous soon enough
This is a classic case of VOF model. Have a look at tank flushing tutorial:
http://www.youtube.com/watch?v=xJs0NVivIYk
You need a clear interface between air and water, and Eulerian models (which I suspct you tried) are not suitable for this.
OJ
oj.bulmer is offline   Reply With Quote
Old   June 14, 2013, 11:06
Tanjina Afrin
Thanks for your reply. I have used VOF model for this. Can't set the inlet properly. Last night I tried with volume fraction of water liquid in inlet 0.5. After 500 run, result is look like the attached image.
Old   June 30, 2013, 18:32
Hossein
hossein65 is on a distinguished road
you have to patch the water on your reservoir
your problem is transient, so, don't use steady solver
pressure inlet seems OK, but the major issue is that you have to make sure there is no water in your pressure inlet as you want to make the reservoir empty
Hossein Amini
PhD student in Biochemical Engineering; Computational Science and Engineering department;
North Carolina Agricultural and Technical State University
hossein65 is offline   Reply With Quote
Old   July 1, 2013, 13:06
Tanjina Afrin
Thanks a lot Hossein. Finally I have solved my this BC problem some days ago and model is given the expected results. I already did exactly what you said in this thread.
Now I am trying to set up an different model. And facing problem with geometry. Should I discuss about it i this thread, or will I start a new thread ? Please let me know.
fluent 14, inlet, workbench 14
[swak4Foam] GroovyBC problem in the defining inlet velocity iampolaris OpenFOAM Community Contributions 7 October 18, 2014 09:25
Problem where FixedValue Inlet meets noSlip Wall VSass OpenFOAM Pre-Processing 0 May 31, 2013 05:13
Problem in setting porosity region for rhoPorousSimpleFoam run_cfd OpenFOAM Pre-Processing 1 May 31, 2011 09:02
Diffuser inlet boundary condition problem Attesz CFX 0 April 4, 2009 04:24
about inlet setting dahuilang Phoenics 1 September 24, 2001 03:53
