Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
multiphase B.C
Old   July 10, 2013, 06:50
Thumbs down multiphase B.C
mehdimoradi
mehdimoradi. is on a distinguished road
Hi
in a multiphase project, inlet of each phase is separated from others. also for outlet, each phase exit from a outlet separate from other phases.
how can define these boundary conditions in fluent software?
please help me.
thanks
mehdimoradi. is offline   Reply With Quote
Old   July 11, 2013, 02:59
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Do the phases separate "automatically" by bouyancy inside your domain, or how does this work? Can you post a picture?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   July 11, 2013, 14:47
mehdimoradi
Thanks RodriguezFatz.
a meshed layout of my project has been attached as a picture format.
Please help me.
Old   July 12, 2013, 01:44
Philipp
So does it mean, the heavy particles entering on the two inlets at the top will fall down, whereas the air moves up and leaves at the top?
What I would do:
Three velocity inlets and two pressure outlets. Set operating density to zero, so you will include static pressure in your calculations. Then, set the pressure of your top outlet to zero and estimate your bottom outlet pressure with hydrostatic pressure drop.
Also, you could use a "degasing" outlet for the top. But I am not sure, what that physically means...
Old   July 12, 2013, 02:30
mehdimoradi
What I would do:
It must be mentioned that in first of test, heavy particles enter bin to fill it completely and then they are exiting the bin with known mass flow rate. although new grain and inert enter the bin with outlet mass flow rate simultaneously. in other word the bin will be loaded completely during the tests.
about pressure out let at bottom, what setting in fluent software must be done to air (phase1) do not exit from the bottom?
Old   July 12, 2013, 04:38
Philipp
You can not create a simple outlet, that prevents air from exiting, as far as I know. How do you think this could work in a real experiment?
Old   July 12, 2013, 07:00
mehdimoradi
In real experiment we use a screw conveyor with small pitch in out let of grain. Thus filled screw conveyor(with grains...) prevent from air exit.
Old   July 18, 2013, 12:09
shubham
shubham208011 is on a distinguished road
See you can assume that there is no air but in practical air is always there.
To visualize this lets assume spherical particle closely packed in a container (stand in vertical direction) which has conical bottom. How closely you pack these particle they end up leaving space between and around them which is called as void (air pockets) and this is the basis of solid bulk density.
Now in my personal opinion (which could be wrong) in your problem from macroscopic point of view we can assume that as air enters the system it rises upward and during upward motion it absorbs moister from only solid and exited from top. Since very small amount of air in compression to solid comes out from bottom and hence it is neglected.
But in CFD (finite volume/fluent) whole volume is divided into very very small control volume (microscopic level) and for each control volume continuity, heat transfer, mass transfer & other equations are solved and here volume fraction of different phases in each small control volume is a significant parameter and hence it is not possible in Fluent/CFD to say that only solid will come out from bottom
shubham208011 is offline   Reply With Quote
Old   July 18, 2013, 12:59
mjgraf is on a distinguished road
not that familiar with Fluent, but in CFX that bottom outlet you can set the volume fraction of air to be 0 and no air will exit. The top Air outlet needs to be set to degassing which will let the air out but act as a wall to the other phases.
mjgraf is offline   Reply With Quote
Old   July 25, 2013, 11:28
Default Question
mehdimoradi
Hello mjgraf
If in Fluent, gravity force is activated, secondary phases exit from top outlet?
Old   July 25, 2013, 11:33
guess that depends on the dynamics and buoyancy.
Multiphase and Non Newtonian fluid wanna88 FLUENT 0 May 27, 2013 00:09
Axis B.C in multiphase problem SH_P FLUENT 8 December 24, 2011 12:54
Urgent! Help on UDF to set B.C. of 3rd type Ray Hong FLUENT 0 December 28, 2005 19:35
How to set B.C. of the 2nd or 3rd type in UDS? Ray Hong FLUENT 0 December 28, 2005 06:03
Problem of B.C. in Eulerian multiphase model Derek Jing FLUENT 0 May 12, 2002 11:52
