July 10, 2013, 06:50 |
multiphase B.C
mehdimoradi
Rep Power: 12 |
Hi
in a multiphase project, inlet of each phase is separated from others. also for outlet, each phase exit from a outlet separate from other phases. how can define these boundary conditions in fluent software? please help me. thanks |
July 11, 2013, 02:59 |
Philipp
Rep Power: 26 |
Do the phases separate "automatically" by bouyancy inside your domain, or how does this work? Can you post a picture?
The skeleton ran out of shampoo in the shower. |
July 11, 2013, 14:47 |
#3 | |
mehdimoradi
Rep Power: 12 |
a meshed layout of my project has been attached as a picture format. Please help me. Untitled.jpg |
July 12, 2013, 01:44 |
Philipp
Rep Power: 26 |
So does it mean, the heavy particles entering on the two inlets at the top will fall down, whereas the air moves up and leaves at the top?
What I would do: Three velocity inlets and two pressure outlets. Set operating density to zero, so you will include static pressure in your calculations. Then, set the pressure of your top outlet to zero and estimate your bottom outlet pressure with hydrostatic pressure drop. Also, you could use a "degasing" outlet for the top. But I am not sure, what that physically means...
July 12, 2013, 02:30 |
#5 | |
mehdimoradi
Rep Power: 12 |
about pressure out let at bottom, what setting in fluent software must be done to air (phase1) do not exit from the bottom? |
July 12, 2013, 04:38 |
Philipp
Rep Power: 26 |
You can not create a simple outlet, that prevents air from exiting, as far as I know. How do you think this could work in a real experiment?
July 12, 2013, 07:00 |
mehdimoradi
Rep Power: 12 |
In real experiment we use a screw conveyor with small pitch in out let of grain. Thus filled screw conveyor(with grains...) prevent from air exit.
July 18, 2013, 12:09 |
shubham
See you can assume that there is no air but in practical air is always there.
To visualize this lets assume spherical particle closely packed in a container (stand in vertical direction) which has conical bottom. How closely you pack these particle they end up leaving space between and around them which is called as void (air pockets) and this is the basis of solid bulk density. Now in my personal opinion (which could be wrong) in your problem from macroscopic point of view we can assume that as air enters the system it rises upward and during upward motion it absorbs moister from only solid and exited from top. Since very small amount of air in compression to solid comes out from bottom and hence it is neglected. But in CFD (finite volume/fluent) whole volume is divided into very very small control volume (microscopic level) and for each control volume continuity, heat transfer, mass transfer & other equations are solved and here volume fraction of different phases in each small control volume is a significant parameter and hence it is not possible in Fluent/CFD to say that only solid will come out from bottom |
July 18, 2013, 12:59 |
Rep Power: 19 |
not that familiar with Fluent, but in CFX that bottom outlet you can set the volume fraction of air to be 0 and no air will exit. The top Air outlet needs to be set to degassing which will let the air out but act as a wall to the other phases.
July 25, 2013, 11:28 |
Question
mehdimoradi
Rep Power: 12 |
Hello mjgraf
If in Fluent, gravity force is activated, secondary phases exit from top outlet? |
July 25, 2013, 11:33 |
#11 |
Rep Power: 19 |
guess that depends on the dynamics and buoyancy.
Multiphase and Non Newtonian fluid | wanna88 | FLUENT | 0 | May 27, 2013 00:09 |
Axis B.C in multiphase problem | SH_P | FLUENT | 8 | December 24, 2011 12:54 |
Urgent! Help on UDF to set B.C. of 3rd type | Ray Hong | FLUENT | 0 | December 28, 2005 19:35 |
How to set B.C. of the 2nd or 3rd type in UDS? | Ray Hong | FLUENT | 0 | December 28, 2005 06:03 |
Problem of B.C. in Eulerian multiphase model | Derek Jing | FLUENT | 0 | May 12, 2002 11:52 |
