October 2, 2013, 11:16 |
Have problem with 2 phase porous media
Juun
Rep Power: 12 |
I am doing a simple filter simulation, shown in the pic.
Phase 2 (particle) will stop and accumulate on the left hand side. Phase 1 (mixture gas) goes through porous media, wall surface reaction happens at the same time on the porous media. Problems 1. As there is no ‘wall’, I setup volumetric reaction in porous media, Am I doing this correct? 2. How to simulate particle accumulation? And the last one problem is that the solver runs ok without multiphase (that is only has mixture gas) … but when I switch it to 2 phases, there is error, saying Divergence detected in AMG solver: phase-1-species-0 Divergence detected in AMG solver: phase-1-species-1 Divergence detected in AMG solver: phase-1-species-2 Divergence detected in AMG solver: phase-1-species-3 Primitive Error at Node 0: floating point exception Primitive Error at Node 1: floating point exception Primitive Error at Node 2: floating point exception Primitive Error at Node 3: floating point exception The species fractions settings are the same in both cases (with and without multiphase) Does anyone have any idea about these problems? Many thanks. |
October 3, 2013, 00:39 |
EMAVI V SURYA SAMPATH
What is your inlet condition ?
Try increasing the pressure relaxation factor and by decreasing the momentum and volume fraction relaxation factor Divergence in AMG solver is because of URF's . Did u define porous zone ? Regards, Sampath Emani |
October 3, 2013, 07:44 |
Juun
Rep Power: 12 |
Sampath, Thanks
inlet conditions: velocity inlet for both phases, at 5 m/s (i chose random number, at this stage), temperature default setting 300k mass fraction (picked randomly for this stage) species 0: 0 species 1: 0.1 species 2: 0.3 species 3: 0.5 phase 2 volume fraction 0.1 yes, I defined a porous zone. Do you mean if I have defined porous zone, particle accumulation will automatically appear? ----------------------------------------------------- after I reduced some URFs, the error has gone... Thanks Thanks a lot Juun |
multiphase flow in porous media | zhou | FLUENT | 2 | August 9, 2012 07:10 |
gas through porous media problem | jiguozhao | CFX | 2 | February 25, 2011 02:14 |
Two phase flow through porous media | cshah4u | ANSYS | 0 | June 22, 2010 07:05 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 15:41 |
Discrete phase modeling on porous media | magnounibo | FLUENT | 0 | April 9, 2009 08:18 |
