Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Spray with Eulerian Wall Film model
Old   October 23, 2013, 08:08
Post Spray with Eulerian Wall Film model
Venkat
Venk is on a distinguished road
Hello everyone,
Please see the attached image. The spray (water) impinges on the walls of vessel, and starts to entrain air inside the vessel. The entrained air that esaceps through the annular gap between the two vessels should shear the water film and thus cause leakage. The objective is to calculate the leakage of water through the gap between the vessels.
I have set up the spray setting for a solid cone, through DPM & Injection. I have enabled Eulerian Wall Film model although not entirely sure of what is gives me. For all the walls, the DPM boundary condition is wall film (not escape or trap or reflect) with zero splashing, and enabled Eulerian Wall Film.
Please can any one suggest if I am going in the right direction.
I am not too sure as to how many particles I should inject. I know the mass flow, velocity of the nozzle, spray cone angle etc.
Please pour in your thoughts and any suggestions to improve the model set up accuracy will be appreciated!
Thanks,
Venk
Last edited by Venk; October 23, 2013 at 08:15. Reason: There is something missing in attachment
Venk is offline   Reply With Quote
dpm, eulerian wall film, fluent multiphase, spray
turn off wall functions in Transition SST model? johnp FLUENT 11 May 26, 2020 13:57
Two-phase Eulerian model for nucleate subcooled boiling Edy OpenFOAM 5 February 11, 2017 16:21
How to include wall lubrication forces in the Eulerian multiphase model xiaoyoyo FLUENT 1 January 4, 2011 16:42
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Standard wall function vs Two layer model C. ORTEGA FLUENT 0 July 7, 2003 08:35
