Plotting mass flow rate at outlet for transient simulation |
August 19, 2015, 13:09 |
Rakibul Islam
Rep Power: 10 |
I am simulating a 3d multi phase (3d, dp, pbns, vof, sstkw, transient) flow through a pressure cell (using fluent). Actually i have been struggling to plot a graph for mass flow rate at outlet vs time. I am just wondering whether it is possible to draw a plot for mass flow rate (outlet) vs time (cfd post).
If possible, any guideline will be highly appreciated. I am a newbie in fluent and cfd post. Rakib |
August 20, 2015, 07:40 |
surface monitor
Rep Power: 11 |
You can set a surface monitor on your outlet and choose to plot and write a text file of it during the simulation. There must exist instructions about how to create suface monitors in Fluent user guide. It's simple. Regards, Parisa |
August 20, 2015, 16:11 |
Rakibul Islam
Rep Power: 10 |
Thanks for the guideline. There is a drop down list where I can select flow time instead of iteration. Didn't know about it before.
Just wondering, is there any way to do the same thing in CFD post (like plotting XY chart). Actually I know the procedure for velocity and pressure (selecting XY transient and location at desired point). But for mass flow rate it doesn't work. Regards Rakib |
August 21, 2015, 03:37 |
Rep Power: 11 |
Well, sorry I don't have a CFDpost here so I can't help you. But sweep through the manual if you have it. It cannot be complicated.
September 5, 2015, 23:46 |
Engr. Shah Jahan
Rep Power: 10 |
In cfd post you can get only instaneous or mean/average plot for variables. For mass flow rate with time you have to define surface monitor during simulation it will write mass flowrate or any other variable with each timestep
DPM total mass flow rate | yow | FLUENT | 0 | July 17, 2015 12:01 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 16:06 |
Split Mass Flow Rate in ANSYS CFX | ashtonJ | CFX | 2 | July 9, 2014 03:08 |
Mass flow rate in outlet | Saturn | FLUENT | 1 | October 11, 2004 09:39 |
Constant mass flow rate / choking outlet bounardy condition | Min Zhu | Main CFD Forum | 1 | September 29, 1998 15:33 |
