Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Eulerian phase gas diameter
Old   July 29, 2015, 20:43
Default Eulerian phase gas diameter
hwet is on a distinguished road
Why does Fluent need a particle diameter for a gaseous Eulerian phase. If it does not require one for air if air is primary phase, why is a particle diameter needed if I have air or any other gas as the secondary phase.
hwet is offline   Reply With Quote
Old   July 30, 2015, 02:44
Cees Haringa
CeesH is on a distinguished road
The primary phase is the continuous phase - it doesn't need a diameter because it is a continuum.
The secondary phase is a discrete phase - it consists of non-connected particulate entities, whether these are droplets, bubbles or particles - these entities have a certain diameter. This diameter needs to be supplied to calculate interphase forces, such as drag.
Best,
Cees
CeesH is offline   Reply With Quote
Old   July 30, 2015, 02:57
So, if the secondary phase was water vapor, how do i know what the diameter is. Should i just randomly put on a very very small diameter for a 'gas type' secondary phase?
Thanks
Old   August 14, 2015, 05:59
Jim
CFDYourself is on a distinguished road
hwet,
it depends on your problem.
if you're modelling gas bubbles in a liquid, then the vapour is the secondary phase.
if you're modelling say, steam condensation, then the liquid is the secondary phase, because you have droplets of liquid suspended in a gas.
CFDYourself is offline   Reply With Quote
bubble diameter definition in multi phase flow boiling simulation FLUENT Abishek FLUENT 13 July 1, 2019 12:12
Eulerian phase diameter-importance? hwet Fluent Multiphase 9 November 22, 2015 04:47
Eulerian phase "screen" boundary condition blacksoil2012 ANSYS 4 November 19, 2015 10:51
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam xpqiu OpenFOAM Community Contributions 8 June 17, 2015 02:08
Eulerian two phase flow&porous media bahman FLUENT 0 April 11, 2013 04:35
