Testing a UDF without Fluent
Old   May 28, 2012, 08:23
Default Testing a UDF without Fluent
unver
unver is on a distinguished road
Dear Friends;
I am cruious if we can easily test the workings of a UDF without pluging it into FLUENT and let it run.
unver is offline   Reply With Quote
Old   May 28, 2012, 16:58
Patrick
Patrick1 is on a distinguished road
Originally Posted by unver View Post
Dear Friends;
Well it would be easy for a simple UDF, to copy and paste the working part of the code, (eg. definition of velocity that changes with time), into a C program, then output the velocity for your desired time range and plot the results as a graph.
But you could just as easily set this up in excel using your exact velocity function. What exactly do you want to test?
Patrick1 is offline   Reply With Quote
Old   May 29, 2012, 06:25
unver
Dear Patrick;
There is no problem with simple problems, as you have mentioned, check can be made by a complier or an excel. However, as the program gets larger with many "DEFINE_**" commands it is difficult to check which one works at which time, so it is easy to lose the track of logic. At the moment, I am doing this track keeping with a paper and a pen, and just wondering if there is a faster way of doing it.
Old   May 29, 2012, 11:45
Patrick
Dear Patrick;
I don't think there is, to save using a pen and paper you could put every DEFINE between comments, and test one at a time, but otherwise there's no easy way to check unless you want to write your own checking program. Unless you have large numbers of UDFs to write there is no point in that, however.
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 13, 2017 23:23
UDF in Fluent Andrew Fluent UDF and Scheme Programming 5 March 7, 2016 03:38
Transient pressure UDF for parallel fluent droberts Fluent UDF and Scheme Programming 5 October 11, 2010 04:13
Using Fluent with a UDF frm a remote m/c aarti FLUENT 2 September 11, 2008 19:53
Can somebody send me a Fluent 6 UDF manual?? KKLAU FLUENT 4 April 14, 2004 16:37
