UDF for body force in DPM
Like Tree2Likes
Old   March 5, 2011, 04:16
Default UDF for body force in DPM
iman vasefi
elah599 is on a distinguished road
I want to write a udf for body force that included (fluid velocity minus particle velocity) in x direction.[du/dt-dv/dt].
can anybody help me how to write du/dt?
elah599 is offline   Reply With Quote
Old   March 5, 2011, 07:58
Amir's Avatar
Amir
Amir is on a distinguished road
first you should specify the cell index that contains particle, then you can use:
du=C_U(c,t)-C_U_M1(c,t)
Amir is offline   Reply With Quote
Old   March 5, 2011, 08:15
iman vasefi
this formula that you wrote,was just for du/dt? I read in help of fluent that the velocity of particle is shown with P_VEL(P)[i] that p is particle tracked and i represnts the coordinate. can you explain the terms that you wrote for that formula?
Old   March 5, 2011, 08:29
Amir's Avatar
Amir
Hi iman,
first I think that you mean acceleration difference?am I right?
yes it's for the flow field part:
du/dt=(C_U(c,t)-C_U_M1(c,t))/CURRENT_TIMESTEP;
for particle part, you can implement user scalars for particles.
Old   March 5, 2011, 11:51
iman vasefi
Hi Amir
thanks for your answering. yes, I mean relative acceleration between fluid and particle. I know that c_u(c,t) is u(cell,thread). but what is U_M1(c,t)? and I have to duplicate exactly "CURRENT_TIMESTEP" to my udf? I owe you lot!!thank you very much Amir
Old   March 5, 2011, 15:07
Amir's Avatar
Amir
Hi Amir
Hi iman,
C_U_M1(c,t) : flow x-velocity in previous one time step
CURRENT_TIMESTEP : flow time step, you should use that to make your UDF independent of FLUENT changes in time step.
regards,
Amir
Old   March 8, 2011, 04:07
iman vasefi
Hi amir
what is your comment aboat this udf?
# include "udf.h"
/* this udf insert a body force on particle in DPM model(A(du/dt-dv/dt)),A is a constant
that is known*/
DEFINE_DPM_BODY_FORCE(particle_body_fprce,cell,thr ead,p)
real bforce;
bforce= A((((C_U(cell,thread)-C_U_M1(cell,thread))/CURRENT_TIMESTEP)-((P_VEL(P)[0]-P_VEL_M1(P)[0])/CURRENT_TIMESTEP)));
return bforce;
Old   March 8, 2011, 09:35
Amir's Avatar
Amir
Hi Iman,
I'm not sure that P_VEL_M1(p) exists in dpm.h library!
if it exist, that's true else you can implement user scalars for particles.
Old   March 9, 2011, 07:00
iman vasefi
Hi amir
I implemented the udf and fluent took this error:
line 7: non-integer subscript expression: pointer to structure.
do you know what that means?
Old   March 9, 2011, 08:00
Amir's Avatar
Amir
it means that something is wrong in variables storage. i.e. you have stored a pointer parameter in a structure kind one.
in above UDF, use A*(...) syntax, also check the validity of P_VEL_M1 function.
regards,
Amir
Old   March 9, 2011, 08:36
iman vasefi
my udf:
# include "udf.h"
that is known*/
real bforce;
bforce= (0.000000000000000000015)*((((C_U(cell,thread)-C_U_M1(cell,thread))/CURRENT_TIMESTEP)-((P_VEL(p)[0]-P_VEL_M1(p)[0])/CURRENT_TIMESTEP)));
return bforce;
how can I check the validity of P_VEL_M1?
regards
Old   March 9, 2011, 11:59
Amir's Avatar
Amir
you can check the validity a function by viewing it's header in src folder, I checked that and it didn't exist so you should use particle scalar array for your purpose as follow:
first you should specify the No. of scalar array in model->discrete phase->UDF tab->user variables -> increase to 1.
use this code. I didn't check that before:
# include "udf.h"
int n=0;
DEFINE_DPM_BODY_FORCE(particle_body_force,p,i)
Thread *t=P_CELL_THREAD(p);
cell_t c=P_CELL(p);
real bforce;
if(n==0) p->user[0]=0.0;
bforce= (1.5e-20)*((C_U(c,t)-C_U_M1(c,t))/CURRENT_TIMESTEP-(P_VEL(p)[0]-p->user[0])/CURRENT_TIMESTEP);
p->user[0]=P_VEL(p)[0];
n+=1;
return bforce;
czhao86 and Shalabh like this.
Old   March 12, 2011, 04:31
iman vasefi
Hi amir,
Thanks for your help,
when I interpret your code there is a error:
line 5: P_CELL_THREAD: undeclared variable
Old   March 12, 2011, 10:17
Amir's Avatar
Amir
Hi Iman,
I checked that as a compiled one, it didn't have any error!
compile your UDF instead.
Old   March 14, 2011, 09:28
iman vasefi
Hi amir
I dont know but something is wrong.I couldent compile that code. I use fluent 12. does it affect? I think there shouldnt be many different between interpret & compile a udf?the version of visual studio is important?
Old   March 14, 2011, 10:40
Amir's Avatar
Amir
Hi Iman,
you can't interpret this UDF because P_CELL and P_CELL_THREAD need FLUENT solution, so you should compile that.
for compiling you need visual C++ 2000 or newer(at least ver 6.) installed on your PC. and ensure that VC++ is linked with FLUENT and your file name doesn't have any space... .
I've checked that before as compiled one. if you post the errors during compilation, I may help you.
Old   March 15, 2011, 08:15
iman vasefi
hi amir
when I compile udf the fluent gives the following error:
(chdir "libudf")()
(chdir "win64\2ddp")()
'nmake' is not recognized as an internal or external command,
operable program or batch file.
Done.
Old   March 15, 2011, 08:41
Amir's Avatar
Amir
you don't have linked FLUENT with VC++.
for more information refer to:
http://www.cfd-online.com/Forums/flu...iling-udf.html
Old   March 15, 2011, 14:49
iman vasefi
hi amir
I have run fluent from VC command prompt, but again i recieved these errors,I'm totally confused!
(system "copy "C:\PROGRA~1\ANSYSI~1\v120\fluent"\fluent12.0.16\s rc\makefile_nt.udf libudf\win64\2ddp\makefile")
1 file(s) copied.
(chdir "libudf")()
# Generating ud_io1.h
vmp.c
c:\program files\ansys inc\v120\fluent\fluent12.0.16\src\config.h(110) : error C2143: syntax error : missing '{' before ':'
c:\program files\ansys inc\v120\fluent\fluent12.0.16\src\config.h(110) : error C2059: syntax error : ':'
C:\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\cor tex\src\dll.h(64) : error C2061: syntax error : identifier 'CX_DLL_GetProc'
C:\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\cor tex\src\dll.h(64) : error C2059: syntax error : ';'
C:\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\cor tex\src\dll.h(64) : error C2059: syntax error : 'type'
..\..\src\vmp.c(6) : warning C4047: 'initializing' : 'Thread *' differs in levels of indirection from 'int'
Done.
Old   March 16, 2011, 04:12
iman vasefi
hi amir
1 file(s) copied.
(chdir "libudf")()
vmp.c
Done.
there is no difference which udf I want to compile. every udf that I want to compile,fluent gives that error.
UDF for defining a body force in Singel ROtating Reference Frame teymourj Fluent UDF and Scheme Programming 9 August 18, 2016 15:33
UDF force on a face enry Fluent UDF and Scheme Programming 10 March 23, 2011 10:48
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
DPM with UDF - Step-by-Step Procedure???? Prashanth FLUENT 3 April 3, 2009 17:45
DPM drag force UDF hedonists FLUENT 0 March 12, 2003 21:10
