Neumann Pressure Boundary Condition with UDF
Like Tree1Likes
  • 1 Post By zahra.hosseini
Old   October 17, 2006, 14:30
Default Neumann Pressure Boundary Condition with UDF
Balder
Dear all, I wonder if someone is able to give me an UDF coding example to force a Neumann b.c. to the pressure field on a pressure outlet, I mean:
dp/dn = 0 where n is the normal of a "pressure outlet" b.c.
Thanks for your attention.
Balder
Old   June 1, 2009, 12:57
souviktor
Souviktor is on a distinguished road
I am stuck with the same problem except the fact that I want to implement du/dx=0 for a laminar pipe flow at the outlet(fully developed condition).
Have you got any work around for your problem so far?
Souviktor is offline   Reply With Quote
Old   November 3, 2009, 11:09
Santhosh
san.pirate is on a distinguished road
Even I've the same problem, haven't got much help, how about you guys. The average static pressure=0 is the nearest matching BC. But I am not sure whether it serves any purpose.
san.pirate is offline   Reply With Quote
Old   February 4, 2010, 04:39
Zahra
zahra.hosseini is on a distinguished road
Why do'nt you use an outflow bc (if u dont have backflow)? this bc sets both dp/dn=0 and dv/dn=0 automatically. if you have backflow through your boundary, then these Boundary Conditions make the problem ill-posed.
happy likes this.
zahra.hosseini is offline   Reply With Quote
Old   February 4, 2010, 09:44
Santhosh
Maintaining static pressure=0 will get you the neumann boundary condition.
I confirmed it with the Ansys CFX tech people.
thank you all..!
Old   August 24, 2010, 14:20
Behrang Asgharian
behrang2009 is on a distinguished road
I have the same problem with Temperature at the inlet for compressible flow.
adiabatic: dT/dx=0
behrang2009 is offline   Reply With Quote
Old   March 19, 2012, 01:37
Default questions
Safia
happy is on a distinguished road
thank you all..!
So what about K, zitha and temp.?does P=0 covers all variables?
IDo you meant CFX or FLUENT?
happy is offline   Reply With Quote
Old   June 25, 2012, 05:43
Satish Gupta
Rahul123 is on a distinguished road
I have written the UDF for convective B.C using DEFINE_PROFILE.....Can any1 tell me how to apply it at the outlet?
Rahul123 is offline   Reply With Quote
Old   July 6, 2012, 11:21
highhopes is on a distinguished road
Do you mean a convective boundary condition for a scalar value? By scalar value I mean temperature, species mass fraction or user defined scalar. If so, You can define both the value itself and the derivative with respect to the normal direction to the surface. Firstly, of course you need to compile or interpret it. Then you will see the name of your udf at the relevant boundary condition panel.
highhopes is offline   Reply With Quote
Pressure boundary condition C-H Kuo Main CFD Forum 18 September 16, 2016 03:19
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
How to give pressure boundary condition in SIMPLER algorithm shyamprasad Main CFD Forum 0 March 16, 2009 23:40
Question about pressure inlet boundary condition. Alina FLUENT 1 November 30, 2007 07:39
