UDS help?
Old   July 26, 2012, 01:40
Unhappy UDS help?
ebadi
eh65 is on a distinguished road
hi
I am beginner in fluent. I have a problem that have a convective B.C in outlet as follows:
that is a independent variable p,v and T.
can anyone help me for this case??
thanks ..
eh65 is offline   Reply With Quote
Old   July 26, 2012, 01:42
ebadi
sorry . the equation is :
Old   July 26, 2012, 02:42
Amir's Avatar
Amir
Amir is on a distinguished road
Dear friend,
you can consider phi as a scalar and solve a modified UDS equation for that easily and set a Dirichlet BC instead, but I think you meant that phi is a dependent variable.
Bests,
Amir
Amir is offline   Reply With Quote
Old   July 26, 2012, 04:19
ebadi
thanks amir
but phi is a independent variable. but i dont know that what to do and begin from which step?
this is the problem of channel that air passes through it.
Old   July 26, 2012, 04:22
Amir's Avatar
Amir
Originally Posted by eh65 View Post
thanks amir
What's the governing equations and what is phi variable?!
Amir
Old   July 26, 2012, 04:41
ebadi
(d/dt)(phi)+ U(d/dx)(phi)= 0
phi is pressure, tempreture and avreaged x-velocity (U)
Old   July 26, 2012, 04:51
Amir's Avatar
Amir
Ah, sorry I think this is sth different at first. Ok, here note that for some BCs you cannot set both velocity and pressure. But you have 2 choices:
1) using a separate UDS equation but it may face some difficulties in its own BCs
2) write a UDF like this:
phi_new=phi_old-U(d/dx phi)*dt
which is a approximation.
Bests,
Amir
Old   July 26, 2012, 05:04
ebadi
thanks
in situation 2 i have to use flux uds?
Old   July 26, 2012, 05:17
Amir's Avatar
Amir
thanks
No! in this situation you wouldn't need any UDS. you're setting phi directly. (note that you can access gradient operator in UDF)
Amir
Old   July 26, 2012, 11:57
ebadi
thanks amir
UDS stored to UDM do not show the same values swati_mohanty FLUENT 0 December 3, 2010 03:46
Doubts UDS Flux, UDS Unsteady for VOF model kel85uk FLUENT 0 March 17, 2010 08:53
A good question about UDS Z FLUENT 1 March 31, 2005 15:14
UDS David FLUENT 1 March 21, 2005 11:31
ODD: no UDS flux across interior boundary Bob FLUENT 1 February 25, 2002 19:15
