January 23, 2013, 15:09 |
Level-Set-Method
Rep Power: 13 |
Hi
I would like to compute the Level-Set-Function in Fluent without using the Level-Set-Method in the GUI. I thought I could use the Macro Domain_LSF_Signed_Distance(Domain *domain, Svar sv_lsf) given in the Source "sg_ls.h".If the LSF is not activated, SV_LSF won't be allocated. So I tried to write the LSF on a UDS. It looked like this. Domain_LSF_Signed_Distance(domain, SV_UDS_5) It actually worked one time, but after that I got this Message: CX_Start_Tree(): Can't cache (3901, 195) Does anybody know how I could deal with this? I'm running out of ideas and I would really appreciate any help. Greetings Marcus Last edited by beer; January 23, 2013 at 16:18. |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
Conservative Level Set Method | mbfranklin@gmail.com | Main CFD Forum | 3 | November 4, 2011 03:44 |
level set method for simulating detonation | Amir | Main CFD Forum | 4 | July 31, 2008 15:13 |
Problem on high density ratio in Level Set method | Kai Yan | Main CFD Forum | 10 | December 25, 2007 06:12 |
How to set environment variables | kanishka | OpenFOAM Installation | 1 | September 4, 2005 10:15 |
