March 24, 2013, 00:52 |
UDF for temperature gradient
Rep Power: 16 |
I have wall i need to apply the current equation as boundary to it:
k*dT/dy=dT/dy where k thermal conductivity T local temperature how i can add it please ? did i need a UDF for it? |
March 25, 2013, 05:36 |
Paritosh Vasava
Rep Power: 22 |
Yes you do need UDF. I think you could use the 'DEFINE PROFILE' macro.
March 26, 2013, 01:27 |
Vaze
Rep Power: 17 |
Hi
You need to use DEFINE_ADJUST function to set C_T_G as zero on the wall of your interest which is called using LOOK_UP_THREAD. Best wishes. Mvee |
March 26, 2013, 15:00 |
Rep Power: 16 |
March 27, 2013, 23:02 |
Vaze
Rep Power: 17 |
C_T_G() - temperature gradient stored at cell locations. Please refer UDF manual.
February 16, 2016, 15:13 |
amin ghaemian
C_T_G is used for compiling gradient over cells... but we need to calculate gradient over face thread!!!!!!!
so what we must to do??????? |
February 25, 2016, 07:03 |
Temporal temperature derivative mass transfer udf
Larry Lekwana
Hi guys,
I am modelling a solid biomass combustion system using a transient, Eulerian multi-phase model in conjunction with a species transport model. I need to write a DEFINE_MASS_TRANSFER udf in order to determine the thermally driven rate of drying of the solid fuel. This requires the the determination of the time derivative of the particle temperature, which I do not know how to code. Please can someone help? Thank you guys in advance for your assistance. |
March 7, 2018, 10:57 |
Rep Power: 8 |
March 7, 2018, 21:01 |
#9 |
Vaze
Rep Power: 17 |
Find out the cell temperature on left and right side of the face. Take difference and divide by its distance. You will need faceloop and cell loop. Hope this helps.
Wall shear stress gradient udf | Andrew | FLUENT | 3 | April 4, 2018 01:36 |
The gradient of void fraction in UDF | summer | FLUENT | 2 | May 20, 2011 03:34 |
UDF temp gradient tutotial | tejasvikrishna | FLUENT | 0 | April 4, 2011 11:10 |
UDF sample for velocity gradient | J.Y.Shin | FLUENT | 2 | January 19, 2007 18:04 |
Gradient in UDF | summer | FLUENT | 0 | September 1, 2006 13:50 |
