August 25, 2013, 20:49 |
Can two udf's used simultaneously in Fluent?
Dinesh
Rep Power: 16 |
Dear Friends,
I want to use DEFINE_PROPERTY udf to vary viscosity as per variation in temperature and second udf DEFINE_EXECUTE_END for modifying output temperature. Can i use both simultaneously? How to use it? (I have written the udf's separately) THanks in advance |
August 26, 2013, 01:17 |
Paritosh Vasava
Rep Power: 22 |
You can put them in one file as following. It should work.
#include ......... #include......... DEFINE_PROPERTY{ ........ ....... } DEFINE_EXECUTE_END{ ........ ....... } |
August 26, 2013, 08:32 |
Dinesh
Rep Power: 16 |
thanks vasava. I will try.
Problem with Compiling UDFs in Ansys Fluent 13 (lnx64) | Ali.beh | Fluent UDF and Scheme Programming | 3 | August 27, 2018 04:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Error in reading Fluent 13 case file in fluent 12 | apurv | FLUENT | 2 | July 12, 2013 07:46 |
Linking pre-compiled UDFs to Fluent | gracerlima | Fluent UDF and Scheme Programming | 2 | April 3, 2010 14:16 |
Fluent - mulitple displays simultaneously? | Chris | FLUENT | 2 | February 14, 2003 09:01 |
