UDF to apply a Spanwise velocity wave on a whole 3D rectangular channel domain |
April 18, 2013, 21:38 |
Hi guys,
I'm modelling a doubly periodic channel flow of rectangular section, to summerize, it's: orientation: x streamwise (mean flow direction-set to periodic) y wall normal (non-slip Boundary condition) z spanwise (periodic) flow direction: x x and z periodic and non-slip condition at the upper and bottom wall, I need some help to write an UDF to impose a spanwise velocity forcing wave travelling downstream which is likely to be coordinate and time dependent like A(z).Sin(Kx.x+Ky.y).Sin(w.t), on the whole domain and update every timestep, I've been looking around but found a 3 yers old thread dealing with roughly the same thing (tank with cg motion). I've already worte UDFs generating waves at the inlet but did that only on Velocity_inlet boundary condition, Is there a way to perform the same thing to a whole domain ie every single node will have its spanwise velocity forcing contribution changing every timestep. I'm wondering if the DEFINE_SOURCE macro is an option for pointing out every cell and adding/updating y momentum? found this on the forum http://www.cfd-online.com/Forums/flu...urce-term.html thanks in advance, best regards. Last edited by QBeast; April 18, 2013 at 22:22. Reason: I've forgotten a detail |
channel, periodic, spanwise, udf, wave |
[waves2Foam] Waves2Foam Related Topics | ngj | OpenFOAM Community Contributions | 660 | August 20, 2018 12:39 |
Velocity boundary condtion UDF help | victoryv | Fluent UDF and Scheme Programming | 2 | October 9, 2012 15:27 |
Channel flow- How to apply "Translational Periodicity" | Giorgitseli | CFX | 3 | May 30, 2011 06:17 |
UDF velocity and temperature | Raj | FLUENT | 3 | February 1, 2009 18:29 |
Fluent UDF load and apply inlet velocity b.c. | Knut Lehmann | Main CFD Forum | 2 | June 29, 2007 04:53 |
