N3V_D,N3V_S(what's the meaning)
Like Tree5Likes
  • 1 Post By zhereal
  • 4 Post By pakk
Old   February 25, 2014, 08:05
Question N3V_D,N3V_S(what's the meaning)
He Zhao
zhereal is on a distinguished road
Could anyone explain me that what‘s the meaning of “N3V_D,N3V_S”?
I saw the two macro in (2.3.9. DEFINE_ZONE_MOTION)in UDF help
#include "udf.h"
DEFINE_ZONE_MOTION(fmotion,omega,axis,origin,veloc ity,time,dtime)
if (time < 0.1)
*omega = 2500.0 * time;
else
*omega = 250.0;
N3V_D (velocity,=,1.0,0.0,0.0);
N3V_S(origin,=,0.0); /* default values, line could be omitted */
N3V_D(axis,=,0.0,0.0,1.0); /* default values, line could be omitted */
return;
but I can’t find “N3V_D,N3V_S” in help.
another question: N3V_S(origin,=,0.0);
I think origin is 3 dimension,(for example N3V_S(origin,=,0.0,0.0,0.0)),I don't
know why it just has 1 dimension in UDF help.
thankyou
Regards,
Zhereal
vavnoon likes this.
zhereal is offline   Reply With Quote
Old   February 25, 2014, 09:41
pakk will become famous soon enough
If you are working in 3D, then N3V_D means the same as NV_D. If you are working in 2D, then N3V_D is not defined. So you can ignore the 3.
In general, these definitions are hidden in "C:\Program Files\ANSYS Inc\v???\fluent\fluent??.?.?\src"
In mem.h and global.h, I found:
NV_D(a,EQ,x0,x1,x2)=ND_D((a)[0],(a)[1],(a)[2],EQ,x0,x1,x2)
ND_D(a0,a1,a2,EQ,x0,x1,x2)=ND_VEC((a0)EQ(x0),(a1)E Q(x1),(a2)EQ(x2))
NV_S(a,EQ,s)=ND_VEC((a)[0]EQ(s),(a)[1]EQ(s),(a)[2]EQ(s))
ND_VEC(x,y,z)=x,y,z
So, expanding your first expression, assuming 3D:
becomes
NV_D (velocity,=,1.0,0.0,0.0);
becomes
ND_D(velocity[0],velocity[1],velocity[2],=,1.0,0.0,0.0)
becomes
ND_VEC(velocity[0]=1.0,velocity[1]=0.0,velocity[2]=0.0)
becomes
Similarly, with your second expression:
N3V_S(origin,=,0.0); becomes
NV_S(origin,=,0.0);
becomes
ND_VEC(origin[0]=0.0,origin[1]=0.0,origin[2]=0.0);
becomes
origin[0]=0.0,origin[1]=0.0,origin[2]=0.0;
So with N3V_S you give every component the same value.
pakk is offline   Reply With Quote
Old   February 25, 2014, 22:41
He Zhao
Thank you very much, pakk!
Today I will have a try.
Old   April 13, 2014, 10:42
sam daysley
daysley is on a distinguished road
ND_VEC(x,y,z)=x,y,z
becomes
becomes
becomes
becomes
NV_S(origin,=,0.0);
becomes
becomes
Hi PAKK and Zhereal,
i don't suppose you know how i would use NV_D or NV_S to change the origin to another position do you? i cant seem to get the rotational origin to change?
thank you in advance
daysley is offline   Reply With Quote
Old   April 13, 2014, 15:11
He Zhao
Hi daysley,
My English is not good.I thick you will want
to change origin,right?
you can use "ND_VEC(origin[0]=a,origin[1]=b,origin[2]=c);"
or "origin[0]=0.0,origin[1]=0.0,origin[2]=0.0;"
have a good day
Old   April 13, 2014, 15:13
sam daysley
Thank you very much zhereal I appreciate it :-)
Old   December 3, 2020, 01:55
Tanuj Srivastava
S_Tanuj is on a distinguished road
ND_VEC(x,y,z)=x,y,z
becomes
becomes
becomes
becomes
NV_S(origin,=,0.0);
becomes
becomes
What if I have to deal with 2-D? I want to fix origin velocity to be 0. I want my system to SHM wrt to origin.
S_Tanuj is offline   Reply With Quote
Old   December 3, 2020, 02:55
In 2D the concept is exactly the same. Just ignore the third coordinate.
Old   December 8, 2020, 01:04
Default frame motion doubt
Tanuj Srivastava
I have a simple 2D box having fluid inside with no other contact from outside (or no interface). When I try to give it SHM, using the code below, by checking frame motion option in cell zone condition, the zone does not look rotate.
#include "udf.h"
#define Freq 0.125
#define angular_freq 2.0*M_PI*Freq
#define tetmax 5.0*M_PI/180
DEFINE_ZONE_MOTION(UCTP8AMP05, omega, axis, origin, velocity, time, dtime)
real t = CURRENT_TIME;
N3V_D(velocity, = , 0.0, 0.0, 0.0);
*omega = tetmax*angular_freq*cos(angular_freq*t);
I followed video on youtube related to frame motion
"https://www.youtube.com/watch?v=tHd2ODQCcxM&t=1039s&ab_channel=Ansys-Tutor"
but I want unsteady case.
So my confusion is that, when I apply frame motion rotating about Z axis with the UDF mentioned above, does it really look to rotate or it looks stationary but in actual it rotates. (In mesh motion you can see it rotating, but it needs some interface I guess)
n3v_d, n3v_s
