April 10, 2017, 06:20 |
turbulent viscosity built-in vs implemented
G Ionut
Rep Power: 9 |
Hi guys,
I want to define a new turbulent viscosity model. First I want to implement the equation from help manual. I extracted and stored in C_UDMIs the values of Turbulent Kinetic Energy, Turbulent Kinetic Energy Dissipation Rate and Turbulent Viscosity. I compared them with the same built-in variables from fluent and I have some differences between each other. Is it ok to have these differences if I compared, theoretically, the same variables? For each figure, Series 1 represents the built-in variable from fluent, Series 2 represents the extracted variables and Series 3 (for the 3rd figure) is the calculated turbulent viscosity using the formula provided in help. The 4th figure shows the line from which the variables was extracted and the comparison was made. Thank you for the support. I attached the code below: Code:
// Preprocessors #include "udf.h" #include "mem.h" // Constants #define CMU 0.09 #define DENSITY 998.2 DEFINE_TURBULENT_VISCOSITY(trb_visc,c,t) { real mu_t, k, epsilon; k = C_K(c,t); C_UDMI(c,t,0) = k; epsilon = C_D(c,t); C_UDMI(c,t,1) = epsilon; mu_t_c = DENSITY*CMU*(k*k)/epsilon; C_UDMI(c,t,2) = mu_t; mu_t_e = C_MU_T(c,t); C_UDMI(c,t,3) = C_MU_T(c,t); return mu_t_e; } |
July 19, 2017, 12:05 |
Vedamt Chittlangia
Rep Power: 9 |
It is not ok to have these differences. The results should be same for both the cases. Also, what you are doing is just returning FLUENT's own viscosity instead of user-defined.
I am also trying to modify turbulent viscosity using this macro. I get the same results as the built-in models when I set the CMU value same as that of GUI panel. It seems that DEFINE_TURBULENT_VISCOSITY() is unable to affect diffusivity of the transport equations. Can you please help me with this. |
Density correction function for turbulent viscosity | Bando | STAR-CCM+ | 1 | July 9, 2017 02:44 |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
[OpenFOAM] turbulent viscosity ratio | bmikuz | ParaView | 2 | July 4, 2014 02:59 |
hel (turbulent viscosity ratio limited) for supersonic combustion problem | omar.2002bh | FLUENT | 2 | September 5, 2012 11:04 |
Turbulent viscosity limited to viscosity... | Cyril | FLUENT | 16 | October 4, 2007 06:12 |
