July 3, 2014, 04:26 |
Accessing C_mu within UDF
Jack Chilvers
Rep Power: 12 |
July 3, 2014, 06:48 |
Manuel
Rep Power: 12 |
Well, maybe you can compute from its definition. But I don't know if you can access the viscous turbulence if you're not using Spalart-Allmaras. Maybe this works: (Cmu=turb.visc / density / K^2 * epsilon )
cmu=C_NUT(c,t)/C_R(c,t)/C_K(c,t)/C_K(c,t)*C_D(c,t); |
July 3, 2014, 10:14 |
Rep Power: 26 |
Don't you mean C_MU_L(c,t)?
July 3, 2014, 11:31 |
Manuel
Rep Power: 12 |
I have had a better look to the manual and saw that the turbulence eddy viscosity is given by C_MU_T(c,t).
So I correct what I said in previous post, you may compute c_mu as: cmu=C_MU_T(c,t)/C_R(c,t)/C_K(c,t)/C_K(c,t)*C_D(c,t); But I wonder... don't you set this parameter as a constant in the turbulence model panel? Why do you need to find it for a specific cell? |
July 19, 2017, 12:12 |
CMU access macro
Vedamt Chittlangia
Rep Power: 9 |
CMU is defined as constant in GUI panel so you can directly put its value in the UDF.
I want to modify CMU value as a local variable. I could not find any macro to do this so I used DEFINE_TURBULENT_VISCOSITY() and put my CMU definition there. But the problem seems that this does not suppress the CMU value that is already present in the viscous dialog box of GUI panel. Can someone help me? Thanks |
fluent, udf |
Problem accessing material properties in UDF for Multiphase Multispecies | pmtgt | Fluent Multiphase | 3 | January 17, 2021 07:11 |
accessing solver data with UDF macros | Dushan | FLUENT | 1 | April 22, 2017 21:05 |
Accessing profile data from a UDF | ral007 | Fluent UDF and Scheme Programming | 1 | October 14, 2015 09:21 |
Accessing phase volm fraction in UDF for a source term in mixture model | aditya.pandare | Fluent UDF and Scheme Programming | 9 | March 20, 2013 23:38 |
UDF - accessing face variable problem | argeus | FLUENT | 2 | February 9, 2011 04:08 |
