December 6, 2015, 14:16 |
Difficulty with UDF code for HEAT FLUX
Saksham
Hi all.
I am really in need of help regarding the following problem. Your concern is appreciated. I am trying to solve a 2D solid rectangular plate conduction problem (length in x and height in y with bottom left corner of plate as the origin). The plate is insulated on the left, right and bottom edge but is subjected to a spatially (in x) varying HEAT FLUX on the top edge. For the top edge, I have made the following UDF code but it is not giving the symmetric solution. The function that you see below for the heat flux is a spatially symmetric function with respect to the centre of the plate. I have paid attention in defining the function correctly with respect to the coordinate system in use. I believe there should be some problem with my UDF C language code below (as I have not clearly understood the use of the x[ND_ND] array). I would be grateful if someone can please put in a small amount of their time and help me out with this problem. //***********// #include "udf.h" DEFINE_PROFILE(heat_flux,thread,i) { real x[ND_ND]; face_t f; real k; begin_f_loop(f,thread) { k=F_CENTROID (x,f,thread); F_PROFILE(f,thread,i) = (-3.073e+20)*k^8 + (6.145e+19)*k^7+ (-4.966e+18)*k^6 + (2.072e+17)*k^5 -(4.718e+15)*k^4 + (5.647e+13)*k^3 + (-3.084e+11)*k^2 + (6.515e+08)*k + (-2.148e+05); // this is the function for the heat flux // } end_f_loop(f,thread); } Last edited by etudiant_IITB; December 6, 2015 at 15:05. Reason: Problem resolved |
December 7, 2015, 08:07 |
Bruno
Rep Power: 21 |
F_CENTROID(x,f,thread) will write the coordinates of the centroid on your x array:
x[0], x[1], x[2] = (x, y and z coordinates) Use those to access each coordinate of the centroid in your equation. |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 07:26 |
Heat flux profile UDF | B.Hamada | Fluent UDF and Scheme Programming | 11 | July 18, 2014 21:39 |
UDF error for flux | ozy | Fluent UDF and Scheme Programming | 0 | June 10, 2014 11:07 |
UDF for Heat Flux | kishan kumar jaiswal | FLUENT | 4 | April 21, 2014 18:01 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
