Specifying region for UDF
Old   August 23, 2016, 04:02
Default Locating applied UDF model
yeongjia is on a distinguished road
Hi all,
I have managed to apply the UDF plasma model on to the designated region on the model by using source terms under cell zone conditions, the only problem that i face now is that; the plasma model applied from the UDF is fairly small compared to the region on the model, and once applied to the region, i'm not exactly sure where it is located within the region (in the middle/towards the right or left side of the region??). Please note that the generated plasma is a triangular shaped figure. Can someone please tell me how to set a specific point for the applied plasma model? Or atleast locate the exact position of the applied plasma model?
I fear that my explanation may be unclear, if so please do ask so that i can rephrase my question further elaborate more on my encounter.
Thanks in advance
Best regards,
J
Last edited by yeongjia; August 24, 2016 at 06:32. Reason: Previous problem solved.
yeongjia is offline   Reply With Quote
Old   August 24, 2016, 02:32
.b.u.m.p.!.
Old   August 24, 2016, 06:32
bumptothetop
Old   August 29, 2016, 05:16
KirMaks
kirmaks is on a distinguished road
Originally Posted by yeongjia View Post
Hi all,
Thanks in advance
Best regards,
J
Hallo,
you need to be a little flexible with the FLUENT and be able to adapt the solutions and examples from the forum, tutorials or programming guides to Your needs. It is also a good point to start with simple things.
I would suggest to initialize the user defined memory and put the plasma values there. These values can be always viewed in Post after the initialisation or solution (if properly defined). Try to search for examples with C_UDMI.
Best regards, Maks.
kirmaks is offline   Reply With Quote
Old   November 5, 2019, 12:29
iyad
pitch is on a distinguished road
greetings
i want to simulate a rotation airfoil with shyy model plasma actuator on leading edge i dont know how to identify that plasma region in the udf for the equation E=E0-K1x-k2Y
pitch is offline   Reply With Quote
Old   November 5, 2019, 12:35
iyad
[QUOTE=yeongjia;615088]Hi all,
Thanks in advance
Best regards,
J
[/i am facing the same case as yours i dont know how to identify that plasma region of shyy model on upper surface of the airfoil can any one help me please]
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
