Please help!!!COMPILED UDFs PROBLEM!!!
Old   April 28, 2004, 09:06
Default Please help!!!COMPILED UDFs PROBLEM!!!
Melih
I have a UDF running perfect in Interpreted mode, but when I try to run it in Compiled mode it gives an error after building the "libudf" library as follows:
///////*Make sure that UDF source files are in the directory
that contains your case and data files. If you have an
existing libudf directory, please remove this directory
to ensure that the latest files are used.The system cannot find the file specified. The system cannot find the file specified.
1 file(s) copied. The system cannot find the file specified.
1 file(s) copied. (system "move user_nt.udf libudf\ntx86\3d")0 (system "copy C:\Fluent.Inc\fluent6.1\src\makefile_nt.udf libudf\ntx86\3d\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\3d")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.*////////
I followed every step in Tutorial. If I ignore this error and continue by clicking "load", i have another error like this:
///////*Opening library "libudf"... Error: open_udf_library: The system cannot find the path specified.
Error Object: ()*///////
My Udf is very simple and it needs only "udf.h" head file and it is also in the same directory where my case and data file take place.Can anyone help my about this problem? Thanks in advance...
Old   April 28, 2004, 11:03
Default Re: Please help!!!COMPILED UDFs PROBLEM!!!
HVN
Normally this problem occurs if you haven't already installed microsoft visual c++.
Old   April 28, 2004, 11:54
Melih GULEREN
Hi HVN,
I have visual C++ in my computer. But, should I tell FLUENT that C++ is installed to overcome this problem? Do you have another advise?
Old   April 28, 2004, 13:21
Allan Walsh
Is "nmake" in the path.
Old   April 28, 2004, 16:29
Melih
You are right Allan,the file "nmake" is not in the path. I think that's why Fluent gives this error:"'nmake' is not recognized as an internal or external command, operable program or batch file", because it does not find the file and execute it. So please, could anyone explain me what should I do, after this step. I strongly need to use compiled Udf, and there must a way to use it. Any help will be highly appreciated.
Old   April 28, 2004, 18:28
co2
are you using dot net ? There are different instructions to compile udfs if you are using dot net.
i am positive that your problem will be solved once you carefully read the instructions at
http://www.fluentusers.com/support/i...udf_serial.htm
Old   April 29, 2004, 03:40
emma
Hi,Melih,
Firstly make sure that you have already installed Visual c/c++ 5.0 or later version correctly. Did you check the environmental variables box before the installation? Do some important variables and values exist and are they in the correct directories,e.g.,include, lib, MSDevDir and Path?
Secondly, please check your case, data and c source file, are they in the right place where they should be as described in the tutorials?
Then I think should be no problem any more.
I hope it helps a bit.
Regards
Emma
Old   April 29, 2004, 08:28
Default Re: THANK YOU for ALL!!!
Melih
By following your recommendations I finally solved this problem. Thank you so much, HVN,Allan,co2 and emma!!!
Old   June 12, 2012, 01:45
amindavari is on a distinguished road
Originally Posted by Melih
;112232
Hi Melih
I have the same problem, could u tell me how did u solve this problem.
thank you in advance.
amindavari is offline   Reply With Quote
Old   August 2, 2013, 01:56
shashank jagtap
shank is on a distinguished road
links not working
shank is offline   Reply With Quote
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
problem in UDF's sangamnath FLUENT 3 December 7, 2005 09:17
URGENT UDF's erosion_macro problem alex FLUENT 7 October 18, 2005 18:18
UDFs' problem Benny FLUENT 14 June 13, 2005 11:05
